Integrate e^(-u^2) du: Polar Coords Explained
  • Thread starter Thread starter Chronos000
    Integral
3 replies · 9K views
Chronos000
I need to integrate e^(-u^2) du
I know I can write this as a double integral of exp(-x^2)dx . exp(-y^2)dy
I'm told I need to change this into polar coordinates but I'm unsure really what's going on
It may help if you describe what you are trying to accomplish. I don't follow how [tex]\int {e^{-{u^2}} du = \int\int e^{-{x^2}} e^{-{y^2}} dx dy[/tex]. I think you are trying to say that it is the product of two integrals, [tex]\int {e^{-{u^2}} du = \int e^{-{x^2}} dx \int e^{-{y^2}} dy[/tex]You can't directly integrate [tex]e^{x^2}[/tex]. I believe you can use a Maclaurin series to approximate a value. Look at the Maclaurin series for [tex]e^x[/tex] and substitute x with [tex]x^2[/tex].
Assuming that your x and y are Cartesian, you can substitute their polar alternative. Just like on the unit circle, the x-horizontal axis component of a point is normally associated as the product of the magnitude of the point from the zero origin and the cosine of the angle, namely [tex]r \cos{\Theta}[/tex]. Use this in your integral and you might get something that can be integrated, but without more about the problem, this may not be correct.
Go to Wolframalpha.com and use their computational engine to integrate E^(-x^2) dx
Their solution is .5*Sqrt(Pi) erf(x) + Constant
the answer I am looking to get is SQRT(Pi).
The x and y were in cartesian yes. I have a part solution which states
"Change to circular polar coordinates (x, y) -> (rho,phi ) and evaluate the angular
integral (remember if you change variables correctly, the area of a ring should
enter as 2*Pi*r*dr)."
If r = (x,y) = (rho.cos(phi), rho.sin(phi) ), I am unsure of the limits or really what's going on. i don't see why you need cylindrical polars? (apart from the fact you can't do it in cartesian)
