Integrating a 2-D Function: x^2+y^2 \leq 4
10 replies · 3K views
the_godfather
[tex]\int\int[/tex] y [tex]\sqrt{x^2+y^2}[/tex]dx dy
x[tex]\geq[/tex] 0, y[tex]\geq[/tex] 0, x^2+y^2 [tex]\leq[/tex] 4
first of all, what are the limits of integration
rearranging x^2+y^2 [tex]\leq[/tex] 4 you get x = 2 - y
this would be my limit of integration for the inner integral yes?
the limits for the outer integral cannot be a function so this would go between 2 and 0?
when the first integration is performed can the square root and y be multiplied out to give
yx + y^2 or is it a case of integrating by parts/substitution?
Ok first off, I think you should understand what the region is a little better. So,
[tex]\left[x^2+y^2\leq4\right] \neq \left[x=2-y\right][/tex] that's just a simple algebra error (I assume when you took the square root you just applied it individually to 4 and y, but you can't do that!).
So, then, what does that region describe? Start off by thinking about the similar bound,
[tex]x^2+y^2=4[/tex]
any idea what that is? And if you do know what it is, what kind of coordinates are very convenient for describing that kind of geometry? :wink:
but if you use polar co-ordinates you don't have a value for theta
r = x^2 + y^2
=4
also how can the y part be obtained?
theta = arc tan (y/x)
this bit confused me
edit: theta can be obtained from what we know that x and y > 0. therefore theta = pi/2
Your region is not described by r = 2; it is described by 0 <= r <= 2. And theta certainly does play a role.
Probably a semantics issue, but you shouldn't say theta equals anything. Theta has a range, just like Mark44 notes that r has a range, and is not simply one value.
Although, r goes from 0 to 2, not 0 to 4.
yes it is a semantic issue.
what i have written on paper is different to my typing. just a bad habit to always press equals on a computer.
what is my next step?
i think once i get the limits sorted i will be fine
the limits are 0<r<2
0<=theta<=pi/2
can the y factor be expressed as r sin theta?
0<=theta<=pi/2
This is only 1/4 of the way around.
Yes, but what about the rest of the integrand, and what does dx dy become?
x and y are both > or = 0. which to me implies only a quarter way around
dx and dy will become dr and d(theta)
[tex]\int[/tex] theta 0 [tex]\int[/tex]2 0 2r sin theta r dr d(theta)
You're right that theta ranges between 0 and pi/2. You put your inequalities x>=0 and y>=0 in the relevant equations rather than in the problem statement, and I missed them.
Your integrand should not have 2r; the original integrand of y*sqrt(x^2 + y^2) becomes r*rsin(theta) = r^2*sin(theta). There is also the factor of r from r dr d(theta), which you correctly show.
Your iterated integral should look like this:
[tex]\int_{\theta = 0}^{\pi/2}~\int_{r = 0}^2 r^3~sin(\theta)~dr~d\theta[/tex]
so i should get an answer of 4?
