Integrating a Multiply Connected Domain Using Cauchy's Theorem
  • Thread starter Thread starter FanofAFan
    Complex Proof
The discussion revolves around verifying an integral related to a polynomial function P(z) defined in terms of its roots and their multiplicities. The context is rooted in complex analysis, specifically the application of Cauchy's Theorem to multiply connected domains.
  • Participants explore the differentiation of the polynomial P(z) and the application of the product rule. There is a focus on understanding the integral of the form 1/(z-zk) and its relation to the logarithmic function. Questions arise regarding the correct expression for P'(z) and the evaluation of the integral.
The discussion is active, with participants offering insights into the differentiation process and integral evaluation. Some guidance has been provided regarding the use of Cauchy's integral theorem, and there is an ongoing exploration of the correct formulation of P'(z)/P(z) and its implications for the integral.
Participants are navigating through the complexities of the problem, with some expressing uncertainty about the application of the product rule and the evaluation of integrals. There is a recognition of the need to clarify assumptions and definitions related to the polynomial and its derivatives.
FanofAFan
Let P(z) = (z-z1)M1(z-z2)M2...(z-zn)Mn
Let [tex]\varsigma[/tex] be a positively directed simple closed curve surrounding all of the zk, k = 1, ... n verify directly that [tex]\int[/tex][tex]\varsigma[/tex] ([tex]\frac{P'(z)}{P(z)}[/tex]dz = 2[tex]\pi[/tex]i(M1+...+Mn)
did product rule, this is an extension of the Cauchy Gorsat Theorem for multiply connected domains and evaluation of integral of 1/(z-zk) dz where [tex]\varsigma[/tex]k
Well, ok. It asked you to verify the equation. And if you used the integral of 1/(z-zk) is 2*pi*i then you did it correctly if you got that answer. What's the question? If you don't know how to get that answer then why not? What's P'(z)/P(z)? Use the product rule.
First, is the P'(z) = M1(z-z1)M1-1M2(z-z1)M2-1... etc?
Second, is the intergral of 1/(z-zk) just ln(z-zk)? I just not sure how you got 2pi*i?
No, that's not P'(z). You didn't use the product rule, now did you? Furthermore the integral of 1/(z-zk) around a counterclockwise contour enclosing zk is 2*pi*i. Isn't that Cauchy's integral theorem?
P'(z) = M1(z-z1)M1-1(z-z2)M2...(z-zn)Mn +M2(z-z1)M1(z-z2)M2-1...(z-zn)Mn +...+ Mn(z-z1)M1(z-z2)M2...(z-zn)Mn-1
Right! Now divide by P(z). It's a lot harder to write all that out than to say what the answer is.
M1(z-z1)M1-1 + M2(z-z2)M2-1 +...+Mn(z-zn)Mn-1
and the integral of that is just (z-z1)M1 + (z-z2)M2 .. etc?
and the integral of that is just (z-z1) + (z-z2).. etc?
Wrong! Isn't it M1/(z-z1)+M2/(z-z2)...+Mn/(z-zn)?
wait the integral is M1/(z-z1)+M2/(z-z2)...+Mn/(z-zn)...
If you can get behind me and believe that's what P'(z)/P(z) is then yes, that's the integrand. Tell me again why that is what P'(z)/P(z) is.
so i got the integral of M1(z-z)M1-1/(z-z1)M1 + ... + etc
which by my attempt in wolfram is M1/(z-z1)
http://www.wolframalpha.com/input/?i=y%28x-1%29^%28y-1%29+%2F%28x-1%29^y
Ok, so you want the integral of M1/(z-z1)+...+Mn/(z-zn) around a contour surrounding all of the zi, right? Integrate it term by term using Cauchy.
