Integrating Elliptical Density: A Simplified Approach Using Cross Products
27 replies · 5K views
mantgx
∫∫D√(9x2+4y2) dx dyD is the region: x2/4+y2/9=1
My understanding is that i have to integrate the function of a density to calculate the mass of plate which is ellipse. Problem is i can't and shouldn't be able to integrate this integral at my level, so am i missing some way of simplification?
Zondrina said:
Why not let ##x = 2u## and ##y = 3v##.
Then switch to polar.
i do not understand how this will help.
can please someone solve the problem for me I am desperate
There's a theorem you should be familiar with, it should be along the lines of:
##\int_R \int f(x,y) dxdy = \int_{R'} \int f(u,v) |J| dudv##.
Where ##|J|## is the Jacobian matrix of the transformation, ##R## and ##R'## are the regions. You have an integral, which looks like the left side of the above theorem. The theorem tells you that you can change the region and co-ordinates of a double integral, and get the same answer.
So making the substitution I noted in an earlier post, what happens to the region ##D##? It gets mapped to some region ##D'## through an invertible map. What is the result of plugging the substitution into the integral on the right?
∫∫R'√(36u^2+12v^2) J du dv
No, the integral becomes ##36 \int \int_{D'} \sqrt{u^2 + v^2} |J| dudv##. Where of course ##dx = 2du## and ##dy = 3dv##.
The region ##D → D' := u^2 + v^2 = 1##. Notice this is the equation of a circle with radius 1.
The Jacobian is the matrix of partial derivatives of the transformation. Can you compute it?
For reference: http://en.wikipedia.org/wiki/Jacobian_matrix_and_determinant
What is ##4\times 3^2## and what is the expression for ##J##?
If you are not familiar with jacobians, try the following instead: what is ##du## if ##u = x/2##? (It is ok to use this type of reasoning as long as you are making parameter transformations of the type considered here, i.e., u = f(x) and v = g(y))
ok, i understand a little now.
J=6 ?
is the final solution 36pi?
Orodruin said:
I would have agreed if you did not still have the jacobian in your expression.
Whoops, my bad. Didn't notice that while typing.
your assumption is correct
thank you guys 100x times
What is the shape of the region bounded by the line ##\frac{x^2}{4}+\frac{y^2}{9}=1## ?
You can rewrite the square root in the integrand as ##\sqrt{9x^2+4y^2}=6\sqrt{x^2/4+y^2/9}=6##, so you have the integral ##\int _D{dxdy}## which is the area of the shape bounded by the line ##\frac{x^2}{2^2}+\frac{y^2}{9}=1##.
ehild
ehild
The integrand is not constant in the area. There is an obvious typo in the formulation where D is defined as being ##\frac{x^2}{2^2}+\frac{y^2}{9}=1##. It should read ##\frac{x^2}{2^2}+\frac{y^2}{9}\leq 1##. Otherwise D would have measure 0, which would result in 0.
The problem was already solved by OP: you make the substitution
x = 2 r \cos\theta,\quad y=3 r\sin\theta
which brings the entire problem to an integral of ##36r## over the unit disk.
Another way of looking at the Jacobian: In analogy with polar coordinates an "obvious" substitution or parameterization is [itex]x= 2r cos(\theta)[/itex], [itex]y= 3r sin(\theta)[/itex]. We can represent the surface by the "position vector" [itex]\vec{v}= 2r cos(\theta)\vec{i}+ 3r sin(\theta)\vec{j}[/itex]. The derivative vectors, [itex]\vec{v}_r= 2 cos(\theta)\vec{i}- 3 sin(\theta)\vec{j}[/itex] and [itex]\vec{v}_\theta= -2r sin(\theta)\vec{i}+ 3r cos(\theta)\vec{k}[/itex] are tangent to the surface and contain metric information in their directions. Their cross product, [itex]6r \vec{k}[/itex], is perpendicular to the surface and gives the differential of area: [itex]dxdy= 6r drd\theta[/itex].
The integrand is [itex]\sqrt{9x^2+ 4y^2}= \sqrt{9(4r^2 cos^2(\theta))+ 4(9r^2 sin^2(\theta))}= 6r[/itex]
So that the integral is [itex]\int_{r= 0}^1\int_{\theta= 0}^{2\pi} (6r)(6r drd\theta)= 36\int_{r=0}^1\int_{\theta= 0}^{2\pi} r^2 drd\theta[/itex]
I would agree but for the introduction of the 3D cross product to solve a 2D problem, since the method is much more general, applies to arbitrary dimensions, and there is no need to reference a 3D space. Instead I would reference the determinant as the area (or more generally, the n-volume, of the parallelogram spanned by the columns/rows), which for two vectors in 3D just so happens to be the magnitude of the cross product.
