Integrating tan^3 x: Tips and Tricks for Solving ∫tan3x dx
  • Thread starter Thread starter Cali920
    Dx Integrate
The discussion revolves around the integral ∫tan^3(x) dx, with participants exploring various approaches to solve it. The subject area includes integration techniques and trigonometric identities.
  • Mixed
  • Participants discuss breaking down the integral into simpler components, such as using substitutions and identities. There are attempts to clarify the misunderstanding regarding the separation of integrals, with some suggesting the use of u-substitution and others questioning the validity of certain steps taken in the process.
The conversation is ongoing, with various interpretations being explored. Some participants provide guidance on the integration process, while others express confusion about specific steps and the application of trigonometric identities. There is no explicit consensus yet, but several productive directions have been suggested.
Participants are navigating through potential typos and misunderstandings related to the integral's formulation. There are mentions of needing to clarify the use of secant and tangent functions in the context of integration.
Cali920
∫tan3x dx
2. The attempt at a solution
∫tan x + ∫tan2x
∫tan x (sec2x - 1) dx
∫(tan x (sec2x - tan x) dx
∫tan x sec2x dx - ∫tan x dx
u = sec x
du = sec x tan x dx
∫tan x sec x sec x - ∫tan x dx
Now I'm stuck..
∫ du * u - ∫ tan x dx ?
For the second part, tan(x) = sin(x)/cos(x), and a simple u substitution should be fine for that.
so ∫ du * u - (sin x /cos x)? What do I do with the du * u? I'm confused...
Thanks for the response! I appreciate it!
it is ∫ u * du- ∫(sin x /cos x)dx and maybe you should learn the basics of integration before you even use substitution. The integral of x is (x^2)/2, so ∫ u * du = (u^2)/2.
I presume it was a typo, but of course, "[itex]\int tan^3(x) dx[/itex]" is NOT "[itex]\int tan(x) dx+ \int tan(x) dx[/itex]".
Personally, I would have written this integral as [itex]\int \frac{sin^3(x)}{cos^3(x)} dx[/itex] and used the standard "odd power of sine or cosine" technique: factor out one of the sines to use with the dx:
[tex]\int \frac{sin^2(x)}{cos^3(x)} sin(x)dx= \int \frac{1- cos^2(x)}{cos^3(x)} (sin(x)dx)[/tex]
and let u= cos(x), du= - sin(x)dx, to get
[tex]\int \frac{1- u^2}{u^3} (- du)= -\int (u^{-3}- u^{-1})du= \int (u^{-1}- u^{-3})du[/tex]
missn525 said:
∫tan3x dx2. The attempt at a solution
∫tan x + ∫tan2x
Just to set the record straight, ∫tan3x dx ≠ ∫tan x dx + ∫tan2[/color]x dx
I think that's what HallsOfIvy was attempting to say, but omitted the exponent on the second integral.
If you prefer:
##\int tan^3(x) dx = \int (sec^2(x) - 1) tanx dx = \int sec^2(x) tan(x) dx - \int tan(x) dx##
Both the latter integrals can be integrated quite easily. For the integral on the left, set ##u = sec(x) \Rightarrow du = sec(x)tan(x)dx##.
Yea, I assumed that was a typo since the rest of the work was correct.
AH! I didn't even realize I did that.
= ∫ tan x * ∫ tan2x
= ∫ tan x (sec2x - 1) dx
= ∫ (tan x sec2x) dx - ∫ (tan x) dx
u = tan x
du = sec2x dx
= ∫ u * du - ∫ u
Is this correct so far?Or can you do two u substitutions?:
= ∫ tan x * ∫ tan2x
u = tan x & u = cos x
du = sec2x dx & du = -sin x dx?
= ∫ tan x * ∫ tan2x
Right off the bat you have a mistake. ∫tan3(x)dx ≠ ∫ tan x dx * ∫ tan2x dx
u = tan x
du = sec2x dx
= ∫ u * du - ∫ u
The first integral looks OK, but not the second. It's missing the du factor. In addition, the same substitution you're using in the first integral won't work in the second.
I believe the OP is confused about the integral operation commuting over multiplication.
Please note:
##\int f(x) g(x) dx ≠ \int f(x) dx \int g(x) dx##
So for example ##\int tan^3(x) dx = \int tan^2(x)tan(x) dx ≠ \int tan^2(x) dx \int tan(x) dx##
you need sec(x)^2 as a factor
$$\tan^3(x)=\frac{\tan^3(x)}{\tan^2(x)+1}\sec^2(x)=\left( \tan(x) - \frac{\tan(x)}{\tan^2(x)+1} \right) \sec^2(x)$$
Please note:
Oh okay. So then what can I do if I can't do ∫ tan x dx * ∫ tan2x dx?
Look at post #7, I already gave you most of the work really.
Just note that ##sec^2(x) - tan^2(x) = 1##. Much like ##sin^2(x) + cos^2(x) = 1##. If you want to get your hands dirty, ##csc^2(x) - cot^2(x) = 1## can also be useful for these trig integrals.
Zondrina said:
If you prefer:
I think I started off doing that originally then got stuck which is why I tried a different u substitution but ->(from my first post):
=∫tan x (sec2x - 1) dx
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
missn525 said:
I think I started off doing that originally then got stuck (from my first post):
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
Watch the second line there. You have an extra bracket you don't need.
So far that looks fine. I'm sure you can integrate udu, the second integral can be easily solved by letting ##tan(x) = \frac{sin(x)}{cos(x)}## and making a simple substitution.
Continue what you were doing earlier.
∫ tan3 x dx[/color]
[STRIKE]= ∫ tan x * ∫ tan2x
[/STRIKE]= ∫ tan x (sec2x - 1) dx
u = tan x
du = sec2x dx
= ∫ u * du - ∫ u
I've already replied about the first integral being OK, but the second one is not OK.
whoops! THANK YOU!
∫(tan x sec2x - tan x) dx
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
= 1/2 u^2 + C -∫ (sin x / cos x) dx?
so u = cos x?
missn525 said:
whoops! THANK YOU!
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
= 1/2 u^2 + C -∫ sin x / cos x dx?
so u = cos x?
While I'm sure you meant ##sec^2(x)## on those lines, you should make it explicit or someone might confuse it for ##sec(2x)##.
Yes ##u = cos(x)## so that ##-du = sin(x) dx##.
Just didn't copy and paste right. But thanks again! I really appreciate it.
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
= u2/2 + C -∫ (sin x / cos x) dx
u = cos x
du = - sin x dx → - du = sin x dx
so then u2/2 + C + du/u?
u = sec x
du = sec x tan x dx
∫udu - ∫tan x dx ?
u = cos x
Close, but watch your negative sign, it doesn't just 'disappear' because you integrated. The integrand itself looks fine though.
I made it positive I thought? because it was - - du/u?
How did ∫du/u become just du/u?
The integral sign shouldn't just disappear.
Looks like you knew the answer already then, I should've read that more carefully. I just knew that ##\int tan(x) dx = - ln|cos(x)| + c = ln|sec(x)| + c##. So I jumped a bit there by accident and forgot the negative myself.
That's okay! Thank you! & I forgot to put the sign in there! THANK YOU Mark44!
u = cos x
so then u2/2 + C + ∫ du/u
Okay, but I'm not sure where to go from here or how to integrate du/u?
$$\int \! \frac{\mathrm{d}u}{u}=\log(|u|)+\mathrm{Constant}$$
Thank you! Is that a rule?
u = cos x
= u2/2 + C + ∫ du/u
= u2/2 + C + log (|u|) + C
then plug back in u?
= u2/2 + C + log (|cos x|) + C?
wait I think there is a sign mishap somewhere if we put the integral sign back in...oh no.
u = cos x
du = - sin x dx → -du = sin x dx
= u2/2 + C - ∫ -du/u
= u2/2 + C - (- [log (|u|) + C])?
No that looks fine. Except you have another ##u## sitting around that you need to sub back in for. You can also combine both constant terms into one constant term. Call it ##C##.
Yes it is also a rule that ##\int \frac{1}{x} dx = ln|x|##.
##\int x^n dx =##
##\frac{x^{n+1}}{n+1}## if ##n ≠ -1##
##\ln|x|## if ##n = -1##
  • · Replies 22 ·
