Integrating the Function: $\frac{dv}{dt}=g-\frac{c}{m}v$
The discussion revolves around integrating the differential equation given by \(\frac{dv}{dt}=g-\frac{c}{m}v\), which is related to dynamics and motion under forces. Participants are exploring various methods of integration and addressing potential mistakes in their approaches.
  • Participants discuss rearranging the equation for integration and question the validity of splitting denominators. There are attempts to apply separation of variables and integrate both sides, with some participants expressing confusion about the integration process and the handling of constants.
The discussion is active, with participants providing insights into integration techniques and questioning each other's steps. Some guidance has been offered regarding substitution methods and the importance of including constants of integration, indicating a productive exchange of ideas.
One participant notes that this problem is not for formal homework but rather a challenge posed by a housemate, which may influence the level of rigor in the discussion.
bortonj88
Hi everyone
I am looking at integrating this function,
[tex]\frac{dv}{dt}[/tex]=g-[tex]\frac{c}{m}[/tex]v
So far i have rearranged the function to get,
([tex]\int[/tex]1/g - [tex]\int[/tex]1/(cv/m))* dv= [tex]\int[/tex]dt
Thanks
JB
Are you saying:
[tex]\frac{dv}{dt}=g-\frac{c_V}{m}[/tex]
and this rearranges to
[tex]\int\frac{1}{g}dv -\int\frac{1}{\frac{c_V}{m}}dv=\int dt[/tex]
If so, there is a mistake because you can't split apart a denominator like that.
bortonj88 said:
Hi everyone
Thanks
JB
There are at least a couple of ways of solving this differential equation, one of which is separation.
[tex]\frac{dv}{dt} = g -\frac{c}{m}v[/tex]
[tex]\Rightarrow \frac{dv}{g -\frac{c}{m}v} = dt[/tex]
[tex]\Rightarrow \frac{dv}{gm -cv} = \frac{1}{m}dt[/tex]
Tip: Use only one pair of tex tags per line rather than sprinkling them in the line.
yeah, sorry, i made a mistake with that.
It was meant to read;
[tex]\int[/tex](1/(g-(c/m)v)) dv = [tex]\int[/tex]dt
Thanks
JB
[tex] \Rightarrow \frac{dv}{gm -cv} = \frac{1}{m}dt[/tex]
Yeah i had this, i then integrated to get
[tex] \Rightarrow ln{gm -cv} = \frac{1}{m}t[/tex]
sorry, meant to read
[tex] <br /> \Rightarrow ln({gm -cv}) = \frac{1}{m}t<br /> [/tex]
What was the substitution you used on the left side? Also, where is the constant of integration on the right side?
[tex]ln(gm -cv) = \frac{1}{m}t[/tex]
thats the problem, i couldn't figure out how to do the integral on the left hand side, so I used quickmath.
If you have a suggestion please let me know, as this isn't homework, my housemate gave it to me to try and solve and now its really bugging me!
As for the constant, inital conditions are v=0 when t=0, and therefore the constant is not used, or so i thought
The substitution is u = gm - cv, so du = -cdv. You need a factor of -c on the left, which you can get by multiplying the numerator by -c and also multiplying by -1/c.
Here's the left side.
[tex]\int \frac{dv}{gm -cv} = \frac{-1}{c}\int \frac{-cdv}{gm -cv}[/tex]
[tex]= \frac{-1}{c}\int \frac{du}{u}[/tex]
Can you finish it. Don't forget to undo the substitution.
Regarding the constant, it's safer to put it in, and then if it's zero you can remove it.
