Integrating with Double Limits: X or Y? Calculating the Correct Integral
The discussion revolves around determining the correct limits for a double integral in the context of calculating an area between functions. The original poster is uncertain about whether to use x or y as the variable for integration limits.
  • Participants discuss the order of integration and the appropriate limits for x and y. There are questions about the setup of the integral and the implications of interchanging the variables. Some participants express confusion regarding the bounds and the area being integrated.
Several participants have provided insights into the integration process and the limits involved. There is an ongoing exploration of different interpretations of the problem, particularly regarding the correct limits and the area of integration. No consensus has been reached, and some participants are questioning the correctness of previous results.
There is mention of a test approaching, which adds urgency to the discussion. Additionally, there are indications that the region of integration may extend below the x-axis, which has not been fully addressed in the initial posts.
MisterP
Hello. I have this double integral I have to calculate.
Shown below
242015
So i drew sketch.
242016
And I do not understand, how to write integral for calculation, which I should use, X or Y on limit?
242017
Is one of them right?
First answer gives me 65,7
Second 383,4
Hi P,
For which variable are the limits you write ?
What is the first variable you integrate over ?
As long as interchanging integration variables does not give you the same result, please post a bit more of your work...:rolleyes:
I wrote that integral for area I need to calculate.. the are between functions x=y^2-4; y = 0 and x=5
First, I integrate (x+2y)
How ?
X as constant
x+2y is the integrand (the function to integrate)
You have to integate over an area. The shaded area in your picture
You can choose to integrate first over x and then over y, or vice versa.
MisterP said:
X as constant
Ok, so you first integrate over y. What are the bounds ?
Bounds are limits? English is not my native..
I know how to integrate, I just got confused on which should be as a limit, x = or y = . I have test closing in 15min
Yes limits
X limits are from -4 to 5 and Y limits are from 0 to sqrt(4+x)?
Yes. To answer your original question: the second is correct. For an integration over y you need a limit that is a function of x
and 65,7 is not the right answer :D
The result of integrating over y is a function of x only. Then you integrate that over x
I do not get it, why is 65,7 wrong?
I got the same result as calculator and it says it is wrong (online test)
Beats me. I find ##\ (xy+y^2) \Big |_0^\sqrt{x+4} = x\sqrt{x+4}+x+4 \ ## Integrate that from -4 to 5 (I use a calculator too) gets same answer as you.
Now the hammer: If we do the integration over x first, the limits are ##y^2-4## and 5
I find ##\ ({1\over 2}x^2+2xy) \Big |_{y^2-4}^5 = 12.5 + 10 y - {1\over 2} (y^2-4)^2 - 2y (y^2-4) \ ##
Integrate that from 0 to 3 using the tool again gets me the same answer again.
(after I found and fixed my own mistake o:) ) :smile:
All I can conclude is: there is something wrong with the test answer
By the way: #16 is an example of what I mean when I ask
There is no indication in post #1 that ##y \ge 0##. Based on that post, the region you are integrating over should extend down below the x-axis.
o:)o:)o:)
Like this.
242024
242025
Yes, so it looks like it was just all times 2 :)
Be Careful about such a leap.
Added in Edit:
I should have said:
No. It's definitely not as simple as multiplying by 2.
  • · Replies 17 ·
