Can dx/dy always be used for integration and derivation on a circle?
The discussion clarifies that the relationship dx/dy = x/y is not universally valid, particularly when considering functions like y = x^2, where dy/dx does not equal y/x. It emphasizes the importance of understanding the conditions under which this relationship holds true. The conversation also highlights the distinction between secant and tangent lines, explaining that the secant line's slope represents an average rate of change, while the tangent line's slope reflects an instantaneous rate of change. Counter-examples are provided to illustrate the limitations of applying this formula. Overall, the use of dx/dy = x/y is conditional and requires careful consideration of the specific function involved.
SHOORY
is dx/dy= x/y
if yes can i use it always
for example in a circle
dA/dtheta=A/360
if its right sometimes what are the conditions of using it
Generally, no it is not. (You can integrate the expression to find the conditions under which it is true.)
Likes Delta2 and SHOORY
And it is quite easy to find counter-examples. For example, let ##y = x^2##. Then ##dy/dx = 2x \neq y/x = x##.
Likes SHOORY
ok thank you
See the graph below for an illustration. The secant is the line through the origin that cuts the curve at (x,y); its slope is y/x. The tangent is the line that touches the curve at (x,y); its slope is dy/dx, the instantaneous slope of the curve at (x,y), or the rate of change of y with x at that point.
Likes SHOORY, Orodruin and Delta2
  • · Replies 16 ·
