Integration by partial fractions.
12 replies · 2K views · last reply
Econometricia
1.[tex]\int[/tex]2x^2+x+9/(9x+1)(x^2+9) dx
2. (A/9x+1) + [(Bx + C ) / (x^2 + 9)]
I get the worst numbers when I solve the system. The question is from an old exam and calculators are not allowed. Am I doing something wrong or is there another way to integrate this?
Are you sure of the numbers you are getting? IOW, did you check to make sure that your two separate fractions add up to the larger one?
Yes, I used a solver to check my work because it did not seem right. I am fairly sure the fractions are broken up properly as well. =(
a=37/41 b=5/41 c = 7/41 I mean its not that outrageous I guess. I guess I just assume I do things wrong lol.
Just to make sure, the integrand is
[tex]\frac{2x^2+x+9}{(9x+1)(x^2+9)}[/tex]
and not
[tex]2x^2+x+\frac{9}{(9x+1)(x^2+9)}[/tex]
right? In either case, your values for A, B, and C aren't correct. If the first version of the integrand is the right one, the coefficients come out even less pretty.
Yes the first version is correct. -.- Do you have any suggestions?
your partial fractions expansion is:
[tex] \frac{A}{9 x + 1} + \frac{B \, x + C}{x^{2} + 9}[/tex]
Multiplying both sides by [itex](9 x + 1)(x^{2} + 9)[/itex] and comparing similar terms, you will get 3 equations for 3 unknowns.
I get the following system:
[tex] \left\{<br /> \begin{array}{rcl}<br /> 9 A + C & = & 9 \\<br /> <br /> B + 9 C & = & 1 \\<br /> <br /> A + 9 B & = & 2<br /> \end{array} \right.[/tex]
After you multiply by the denominator, I'd set x=-1/9, which allows you to solve for A, then use the equations Dickfore got to solve for B and C.
361/365 41/365 36/365
It was on an old exam lol. I hope there's nothing like that on our exam =O.
