Integration of a function of x
The discussion revolves around integrating the function ∫(45.1/3)x²(4-2x)³dx. Participants clarify the correct interpretation of the integral and suggest that integration by parts may be unnecessary, advocating for expansion or substitution instead. A user demonstrates the expansion of the polynomial and subsequently applies substitution, yielding a simpler integral to solve. The conversation also includes a reminder to post calculus questions in the appropriate forum section. Overall, the integration process can be simplified through strategic methods rather than relying solely on integration by parts.
chwala
##∫45.1/3x^2 (4-2x)^3dx##[/B]
##45/3∫x^2(4-2x)^3dx = let u = x^2 du= 2x, dv= (4-2x)^3 v=(2-x)/-4 ##
using intergration by parts is this right[/B]
It's not obvious whether you mean ##\frac{45.1}{3x^2 (4 - 2x) ^3}## or ##\frac{45.1}{3}x^2 (4-2x)^3##.
If you want to integrate ##\int \frac{45}{3} x^2(4-2x)^3dx=15 \int x^2(4-2x)^3dx## by parts, you will have to apply it three times and in the end, the polynomial has to be of degree ##6##, for you started with a degree ##5## polynomial. I'm rather sure that performing the multiplication ##x^2(4-2x)^3## and integrating term by term is almost faster.
The formula by parts goes ##\int u'v = uv - \int uv'##
If you are solving ##\int x^2 (4-2x)^3 dx## then integration by parts is perhaps overkill. You could simply expand out all terms or first make the substitution ##u = 4-2x## which means you no longer have to deal with expanding out a cubic power. If you have to use integration by parts, your integration of v is incorrect.
sorry i mean the latter...
I expanded and multiplied out the factors...and got it as follows,
##45/3∫x^2(16-16x+4x^2)(4-2x) = 45/3∫x^2(64-32x-64x+32x^2+16x^2-8x^3)dx = 45/3∫(-8x^5+48x^4-96x^3+64x^2)dx##
this is an easy integral i was just tired, i will try use the substitution method and see what comes out.
now on using substitution
let ##u=4-2x, →dx=du/-2, x= (4-u)/2 ⇒x^2=(16-8u+u^2)/4,
⇒45/3∫((u^2-8u+16)/4)). (u^3) (du/-2) = 45/-24∫(u^5-8u^4+16u^3)du ##
which will give correct solution as the other long method.
Thank you guys, greetings from Africa.
@chwala, please post questions on calculus in the Calculus & Beyond section, not the Precalculus section, where you originally posted this thread.
OK sir
  • · Replies 105 ·
  • · Replies 21 ·
  • · Replies 22 ·
