Integration of an equation relating to electrostatics
26 replies · 3K views
Lazy Rat
Hi I was wondering if anyone could give me a hand with this problem I'm trying to solve.
I am trying to integrate this equation twice. I'm not really sure what to do with the right hand side of the equation.
[/B]
The left side I am ok with i think,
dV/dr = A/r
Any help as to how to deal with the right hand side would be great.
Thank you
Lazy Rat said:
dV/dr = A/r
Is that supposed to be the integral of the left hand side? I don't understand.
How do the variables on the right depend on r?
[/B]
dV/dr = A/r
Thank you
This is 2nd order nonhomogeneous differential equation.above equation can be written as
V''+V'(1/r^2)=-ρf/εε°r
if we suppose that ρ,f are constants or known functions ##\rho(r),f(r)##, then the 2nd order linear nonhomogeneous and with no constant coefficients ODE I get is , by expanding the left hand side:
##V''+\frac{1}{r}V'=-\frac{\rho f}{\epsilon\epsilon_0}##.
Yes your's equation is right i misscalculated
Yes, but as rude man points out, if the variables on the right depend on r, not V, that is a retrograde step.
##-ρf / εε_0## relates to Poisson equation ##pf## is the free charge density and ##ε_0## is the permitivity of free space. So these can be taken as know constants on this occasion.
I am looking to achieve a general solution through integrating twice. With a similar equation for electrostatics and Laplace's equation I have ##{1/r} d/dr(r{dV/dr})=0## , then integrating once we have ##{dV} /{dr} = {A/r}## then twice ##V(r) = A {ln} r + B## .
So how can I solve this in a similar way regarding Poisson's equation?
Thanks for you input guys
In exactly the same way. Multiply out and integrate. What do you get?
@Lazy Rat, BTW the expression for ∇2V = -ρ/ε can also be compacted in spherical coordinates to
(1/r2) d/dr {r2dV/dr} = -ρ/ε
with solution proceeding in the same way haruspex pointed to in his post 9.
So I get the same because the right side I treat as a constant. The answer is still the Laplace general solution ##V(r)= A~ ln (r)~ + B##
Is this correct?
Thank you rude man, may try to tackle in spherical.
Is this correct?
The right side IS a constant but when you integrate (twice in fact) that constant has an impact on the answer.
Do the solution step-by-step & we can show you where you went wrong.
Hi
Ok so first step is to multiply out.
Thus we have for ## \frac 1r \frac d{dr} (r \frac {dV}{dr})= \frac {\rho f} {\epsilon \epsilon_0} ##
## \frac 1r \times r + \frac 1r \times \frac {dV}{dr} + \frac d{dr} \times r +\frac d{dr} \times \frac {dV}{dr} =\frac {\rho f} {\epsilon \epsilon_0} ##
## = 1+ \frac {dV}{dr^2} + \frac {dr}{dr} + \frac {d^2V}{dr} =\frac {\rho f} {\epsilon \epsilon_0} ##
## = \frac {d^2V}{dr2} + \frac 1r \frac {dV}{dr} = \frac {\rho f} {\epsilon \epsilon_0} ##
Is this correct for multiplying out the left side?
Thank you
Lazy Rat said:
Is this correct for multiplying out?
No. If you have an equation like y/x=z then multiplying out gives y=xz.
I see, I've epand the brackets not multiplied out.
## \frac d{dr} (r \frac {dV}{dr})= \frac {\rho f} {\epsilon \epsilon_0} r##
Is this correct?
Can the derivative terms such as ## \frac d{dr} ## be manipulated algebraically, and why is it ## \frac d{dr} ## and not ## \frac {dV}{dr} ## are these the same thing ?
All this is a dark room to me, you are shedding light, I appreciate your time. Thank you.
Is this correct?.
Yes.
You can immediately integrate that. Don't be distracted by the ##(r \frac {dV}{dr})## term. At this stage it is just some function of r. Think of it as ## \frac d{dr} F(r)= \frac {\rho f} {\epsilon \epsilon_0} r##
Lazy Rat said:
Hi
Thank you
Other than you need a - sign in front of ## \frac {\rho f} {\epsilon \epsilon_0} ## yes, that is in fact the expanded version for the Poisson equation for cylindrical coordinates.
Yes, but it is not "multiplying out", and it is not on the simplest path to solving the equation.
You previously solved the Laplace equation without this multiplying-out. Stick to what you were doing before, which was double integrating (1/r)d/dr{rdV/dr)} = 0. Just change "0" to "-ρ/ε". You'll get the same first two terms you did with the "0" plus you'll get a third due to the "-ρ/ε".
rude man said:
You previously solved the Laplace equation without this multiplying-out. Stick to what you were doing before, which was double integrating (1/r)d/dr{rdV/dr) = 0. Just change "0" to "-ρ/ε". You'll get the same first two terms you did with the "0" plus you'll get a third due to the "-ρ/ε".
We seem to be offering conflicting advice, but it might just be a question of terminology. I've started a conversation on which we can resolve this, one hopes.
Having discussed it offline, it seems there was a misunderstanding. rude man agrees that the way is to multiply out in the sense of the step taken in post #16, not to expand the derivatives as in post #14.
Ok thanks for clearing up confusion guys
I think I may have got there, I have after multiplying out
## ∫ \frac d {dr}( r \frac {dV}{dr}) = ∫ - \frac ρ ε {r} ##
Integrating twice
## v(r) = A ~ ln (r) - \frac {ρ r^2} {4 ε} + B ##
Is this correct?
Thank you
Integrating twice
Is this correct?
Thank you
Got it! But you have to append "dr" to both sides of your first equation & clean up the left side.
Ah yes of course the dr, by clean up the left side you mean don't have the ## \frac d {dr} ## in the equation?
Thanks rude man
Thanks rude man
When you add "dr" to the left side, two "dr's" cancel, leaving you with
∫d{r dV/dr} = r dV/dr + constant etc.
Like ∫dy = y + constant.
