Integration of linear functions
Integrating the function (2x+5) using two different methods yields different expressions, but the constant of integration remains arbitrary. The first method results in x^2 + 5x + c, while the second method simplifies to x^2 + 5x + 25/4 + c. Despite the differing constants, they can be merged since both represent arbitrary constants. When applying initial conditions, the constants can be adjusted accordingly to maintain consistency in the final expression. Ultimately, the choice of integration method does not affect the overall solution when constants are appropriately combined.
sgstudent
If i integrate (2x+5) using the simplest rule, i get x2+5x+c, however if i use the linear function method, i would get (2x+5)^2/4 +c so simplifying it i get (4x^2+20x+25)/4 +c=x^2+5x+25/4+c. So does it mean when i use the two different methods my constant,c is different?
linear integration rule
Yes, there's no meaningful difference there.
thanks!
C is an arbitrary constant. It doesn't matter whether you use "c" or "25/4+ c" it still represents some arbitrary constant.
Suppose you were given that dy/dx= 2x+ 5 and that y(0)= 1. Clearly y is the integral of 2x+ 5 so, integrating the first way, you would get y(x)= x2+ 5x+ c and then the addtional condition, that y(0)= 1, becomes y(0)= 02+ 5(0)+ c= c= 1 so you answer is y(x)= x2+ 5x+ 1.
Integrating the second way, y(x)= x2+ 5x+ 25/4+ c so that y(0)= 02+ 5(0)+ 25/4+ c= 25/4+ x= 1 so that c= 1- 25/4= -21/4. But that means that y(x)= x2+ 5x+ 25/4- 21/4= x2+ 5x+ 4/4= x2+ 5x+ 1 just as before.
If I ever use a method of integration that gives me some constant such as +1 but then I also have a +c added on the end, I just merge them together to make it +c2 or +k or if the teacher isn't strict / doesn't care I'll just get rid of the 1.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
