Integration of separate variables
3 replies · 3K views
Milly
Liquid is flowing into a small tank which has a leak. Initially the tank is empty and, t minutes later, the volume of liquid in the tank is V cm3 . The liquid is flowing into the tank at a constant rate of 80 cm3 per minute. Because of the leak, liquid is being lost from the tank at a rate which, at any instant, is equal to kV cm3 per minute where k is a positive constant.
The equation becomes dv/dt=80−kv but why can't I use dv(gain)/dt = 80 and dv(lost)/dt = kv intergrate both equation and minus V(lost) from V(gain) to get V ?
Hi Milly! :)
You could, but then you need another DE since your second DE depends on v, which is different from v(lost).
You would need the additional equation dv = dv(gain) - dv(lost) to complete the set of differential equations.
Then, when you make the proper substitutions, you'll get dv/dt=80−kv.
Milly said:
What is DE?
DE stands for differential equation.
