Integration problems. (Integration by parts)
5 replies · 36K views
BioCore
Hi, I have a test coming up soon so I was doing some questions from the textbook when I stumbled upon this one and I'm stuck after like 5 tries. Here is the question:
[tex]\int[/tex]cos^2(x)dx
Solve.
the question then states we should solve using this:
cos^2(x)dx = (cos x)(cos x)
which gives us:
[tex]\int[/tex]cos^2(x)dx = sinxcosx + [tex]\int[/tex]sin^2(x)dx
finally we should use sin^2(x) + cos^2(x) = 1 to replace the sin^2(x) at the right side of integral.
so basically I tried using integral by parts, since we are studying this topic currently
and set:
u= 1 - cos^2(x) and dv = dx
du = 2cosxsinx and v = x
When I plug in the values into the integration and try to solve I don't end up with their answer. I must be overlooking something and this is where I am stuck:
[tex]\int[/tex]cos^2(x)dx = sinxcosx + x(1-cos^2x) - [tex]\int[/tex]2xcosxsinx
The final answer should be:
[tex]\int[/tex]cos^2(x)dx = 1/2sinxcosx + 1/2x + C
Thanks for the help.
All problems of that type can be solved using this "formulas" :
[tex]\int[/tex]cos^n(x)dx = 1/nsinxcos^n-1(x) +n-1/n [tex]\int[/tex]sin^n-2(x)dx
[tex]\int[/tex]sin^n(x)dx = -1/nsin^n-1(x)cosx +n-1/n [tex]\int[/tex]sin^n-2(x)dx
well, you could also use this identity
cos^2(x)=(1+cos(2x))/2, it would really help you get to the answer pretty quickly, and without needing to do ineg by parts at all.
However, the point of the method that was suggested originally is that, after the first integration you have, as you say,
[tex]\int cos^2(x)dx = sinxcosx + \int sin^2(x)dx[/tex]
Now let [itex]sin^2(x)= 1- cos^2(x)[/itex] and that becomes
[tex]\int cos^2(x)dx= sin(x) cos(x)+ \int (1- cos^2(x))dx[/tex]
[tex]\int cos^2(x)dx= sin(x) cos(x)+ \int dx- \int cos^2(x) dx[/tex]
[tex]\int cos^2(x)dx= sin(x) cos(x)+ x - \int cos^2(x) dx[/tex]
Add [itex]\int cos^2(x)dx[/itex] to both sides of the equation and you are almost done.
Halls off Ivy thanks a lot, I forgot that rule of integration. thanks a lot, yeah now that I tried it out it actually works. Thanks a lot.
[tex]cos^2(x)dx= 1+cos2x/2[/tex]
wat i want to ask is...is this the formula for cos^2x dx or can it be used wid [tex]\int[/tex] too??
