Integration with Heaviside step and Dirac delta functions
5 replies · 4K views · last reply
SpaceDomain
[tex] \int_{-\infty}^{\infty}{u(t)e^{-t}(\delta(t+1)+\delta(t-1))dt[/tex]
[tex] \int_{-\infty}^{t}{u(t)dt = \left\{\begin{array}{cc}0,&\mbox{ if }<br /> t< 0\\t, & \mbox{ if } t>0\end{array}\right.[/tex][tex] \int_{-\infty}^{\infty}{f(t)\delta(t-a)dt} = f(a)[/tex]
[tex] = \int_{-\infty}^{\infty}{u(t)e^{-t}{\delta(t+1)dt}<br /> + \int_{-\infty}^{\infty}{u(t)e^{-t}{\delta(t-1)dt}[/tex]
I obviously could use the second relevant equation if the u(t) term was not in these integrals.
I am stuck. Could someone point me in the right direction?
[tex] = \int_{0}^{\infty}{e^{-t}{\delta(t+1)dt}<br /> + \int_{0}^{\infty}{e^{-t}{\delta(t-1)dt}[/tex]
Is that correct?
[tex] \int_{-\infty}^{\infty}{u(t)dt = \left\{\begin{array}{cc}0,&\mbox{ if }<br /> t< 0\\t, & \mbox{ if } t>0\end{array}\right.[/tex]
The upper limit of the integral should be t, not ∞.
Why does the presence of u(t) stop you? What's the definition of the Heaviside step function?
Is that correct?
Yes.
[tex] <br /> = \int_{0}^{\infty}{e^{-t}{\delta(t+1)dt}<br /> + \int_{0}^{\infty}{e^{-t}{\delta(t-1)dt}<br /> [/tex]
[tex] <br /> = [e^{-t}]_{t=-1}<br /> + [e^{-t}]_{t=1}<br /> [/tex]
[tex][e^{-t}]_{t=-1} = 0[/tex] because [tex]t=-1[/tex] is out of the limits of integration.
[tex][e^{-t}]_{t=-1} <br /> + [e^{-t}]_{t=1} <br /> = \frac{1}{e}[/tex]
Does that look right?
Yes and no. You figured out the answer correctly, but what you wrote isn't correct. For one thing, the first integral isn't equal to [itex][e^{-t}]_{t=-1}[/itex] since [itex][e^{-t}]_{t=-1}=e[/itex]. Second, [itex][e^{-t}]_{t=-1}[/itex] is always equal to e; it's never equal to 0. What you should have written is simply that the first integral is equal to 0 because the delta function is zero over the interval of integration.
