Interested in Understanding Limitations to 12V DC battery applications
The discussion revolves around the challenges and possibilities of obtaining a 24V power source from a typical 12V DC car system, particularly for applications involving a DC motor in a turbo system. Participants explore various methods to achieve this without extensive modifications to the vehicle, considering both theoretical and practical aspects.
  • One participant suggests installing two 12V batteries in parallel and then reconfiguring them in series to achieve 24V when needed.
  • Another proposes using a 24V auto battery and mentions that trucks and military vehicles typically use 24V systems for additional power.
  • A different participant notes that a typical alternator outputs over 200VAC and discusses the possibility of using power converters or inverters to achieve the desired voltage.
  • One participant describes a scenario involving a DC motor for a turbo system, emphasizing the need for 24V to reduce amperage draw and improve efficiency.
  • There are suggestions for using a transformer to convert 12V to 24V specifically for the motor, though concerns about increased amperage draw and transformer capacity are raised.
  • Another participant mentions the potential of using a belt-driven supercharger as an alternative to the proposed DC motor setup.
  • Discussion includes considerations of heat generation in turbo systems and the importance of intercoolers in managing this heat.
Participants express a variety of approaches and ideas, with no clear consensus on the best method to achieve a 24V system from a 12V car. Multiple competing views and suggestions remain unresolved.
Participants highlight limitations related to the efficiency of power conversion, the need for additional components like voltage regulators, and the potential for increased load on the existing battery and alternator system. The discussion also reflects varying levels of expertise and familiarity with electrical systems.
This discussion may be of interest to automotive enthusiasts, engineers, and hobbyists exploring modifications to vehicle electrical systems, particularly those focused on performance enhancements involving DC motors and turbocharging.
Mattsnooze
In a 12V dc typical car how could you possibly obtain a 24 volt power source that would charge off the existing alternator, without upgrading the entire car to run off the 24V power source?
In the engine bay I would like to have access to 24Vdc power so was hoping I could either install two 12Vdc (oddessy marine batteries) and somehow be able to tap off of
24Vs some how without heavily modifiying the car (keep the budget as low as possible).
Thanks in advance to any repliers
matt
You could add 2 x 12 batteries as a separate system - or just use a 24V auto battery. Trucks and military vehicles use 24V systems so they have extra power to run extra equipement. You would have to fit an extra 24V alternator and charging system.
You can easily convert 12V dc to 24V dc if you only want to run some electronics, it wouldn't be very efficent for high power applications.
Welcome to PF, Matt.
This is not one of my areas of knowledge, but I can tell you that a typical alternator puts out over 200VAC. Power converters can either take that from the source and modify it, or take the 12VDC from an auxilliary power tap such as a lighter socket and run it through an inverter.
If you want to run a 24V system, you probably just need to replace your voltage regulator (and every 12V component in your car).
It might be easiest to just go to your local airport and talk to a few sky drivers. Civilian aircraft (at least when I was flying) are 24V systems.
edit: Hey, Mgb... how do you always manage to beat me to the punch? (No age jokes allowed.)
Having a bad day at work, so it's hit 'new posts' on pf or work out which of the dozen mutually incompatible but high priority changes I'm supposed to work on first!
Man, I'm glad that I work in finance rather than engineering. :smile:
You could use a setup that kept the batteries in parallel, then disconnect them and rewire them up in series when you need the 24V.
Actually, that would be a really simple switching circuit. Alternatively, he could set the charging system for 24V, and use a secondary regulator to feed the rest of the vehicle.
Well, I'll explain what I'm doing and see if your all able to expand upon my thoughts
Heres the scenerio without all the science. I have a DSM turbo (14B) off a mitsubishi. The bad part about regular turbo systems is the heat they generate using the exhaust to power the turbo. I would like to use a DC motor (12vdc requires higher ampherage, and less 12V DC motors are available for the application I would like to use it for). 24V dc have a wide veriety of DC motors that would fit my application so was hoping I could maintain my 12VDC car but just add in a power supply that charges off the alternator, but could provide me with 24VDC at a push of a button to turn on the DC motor which will either use a pulley system or direct drive depending on how much space I need and at what speed/rpm/torque will put me at my 1.4 PR. My alternator puts out around 100 amps so the motor ideally would use less than 40 amps at max. Also the good thing about using a dc motor to power the compressor is that speed regulation would be very simple (boost control). I origionally thought about using a power inverter and buying a 120V ac motor but I was concerned about space and about limitaions of power inverters (ampherage, and cost of the inverter itself) I have built a prototype that works fantastically but like I said I need this 24 volt system in my car to make it work as I have built it. Then ofcourse comes the tuning lol (the fun part). IF however someone knows where I can find a 1/3 to 1/2 HP 12VDC motor that has around 5-8000 rpm with a good deal of torque (enough to power a small impeller off a turbo at high speeds (50000-100000 rpm) (thus needing a pulley system) for under 100$ I could purchase that instead of trying to convert to 24 VDC.
Could I not just add a 12VDC to 24VDC transformer to strictly power the DC motor? That would double the ampherage draw on my battery and alternator system though would it not? That transformer would have to handle the 40 amps though my motor draws, so In the end a 12Vdc motor would be the Easiest/Simplist. (suggestions ?)
The whole bases of this project is to boost a car at around 6psi (approx. 80000 rpm at my 1.4 PR) as inexpensive as possible without having as much heat generated by the design of the turbo system (using exhaust to power the compressor side of turbo)
Thanks for the welcome btw, and all your responses!
The timing would seem to be the biggest issue. Not sure how you could tune it.
Why do you have such a concern with the heat in a normal turbo??
CS
Have you considered just using a belt-driven supercharger such as a Paxton? Those mount similarly to an alternator, on the side, so you don't have to cut a hole in your hood.
For a high hp/torque 12VDC motor, check out a local wheelchair supply company. I have 3 surplus wheelchair motors that are 1/2hp 12VDC; they're awesome.
Along with what Danger said you may want to look into intercoolers.
All compressed air gets hot and engines work better if you cool it off before dumping it into the cylinder.
Intercooler is already part of the plan. I have all that I just need the power supply
I have the system built already, EFInd (electrically forced induction) like I said, its built on a flat board that simulates the size in my engine bay to fit the whole setup with the two odessy batteries even.
I have the intercooler designed (just need money to buy a half intercooler but piping will have to be custom). All I need is a way to either get a good 12V dc motor (1/2 hp wheel chair motor I have researched and are perfect but a little bulky for what I want and are really pricey. I can't find any slightly used for sale).
Or plan B some how as I stated above use a readily available decent powered 24V dc motor but have the complications of supplying the 24v dc power to it without it costing too much to convert the car to 24v dc.
The superchargers you list are fine but draw parsistic lag on the motor, while all I'm doing is using an abundant supply of free energy (wicked alternator powering 1 hopefully 2 odessy marine batteries if I can figure a way to run the 24V dc) to power a tdo5h 14b dsm (compressor side) using a pulley/belt system. The bonus is the whole setup (EFInd) for a small 6-8psi boost is under $2000 with tuning incorperated, where as a small turbo setup of same power output would run probably 4000-5000 if done properly.
I'm using a speed control system also for boost control which is why electrically forced induction is made really simple. Its pretty much a variable speed control, (controlling the motor) with a boost guage, and botv still to max out psi at hopefully 8psi max (if they even make a botv at 8psi)
As far as tuning goes I would need a p72 tuned with new maps that opperate with 8psi potential. My stock map sensor will be adiquite so with a proper tune program it will regester in the p72 and it will alter my timing/fuel accordingly. Thats the last thing I buy though, that's going to be 500+ than with dyno and tuning another 200 or so.
Mattsnooze said:
The superchargers you list are fine but draw parsistic lag on the motor, while all I'm doing is using an abundant supply of free energy .
Errrrrr, so you don't think the alternator is going to place a parasitic drag on the engine?
Sorry, not a chance. It will also be much less efficient than direct drive.
There is no such thing as free energy.
This sounds like a pretty dumb idea. Your new alternator + battery + motor system will likely be less efficient than the exhaust-driven turbo you're trying to replace, meaning it will put an even greater load on your engine. Yes, alternators get harder to turn when you apply more electrical load. No, it's not "free energy" at all.
Heat is not really an issue, as compressing the intake air is what raises its temperature, regardless of how you choose to compress it. I doubt that a substantial amount of heat is transferred from the exhaust to the intake side of the turbo in the first place.
The only real advantage I could see would be the ability to dial up whatever boost you want, even at idle, but I hardly see this as a reason to build this at all.
- Warren
I agree with Chroot, but was trying to be polite. An electrical drive would be far less efficient than either a belt drive or a turbo. In the old days, we would disconnect the alternator wires before a race to cut down on the EM drag. A belt driven supercharger such as a 6-71 Roots, if driven independently from the engine, might give you something like 200 extra hp. If the engine is powering it, though, you might see only a 50 hp increase because it takes 150 to run the damned thing. Even a turbo robs power, since it increases the exhaust back-pressure. Since nobody needs any kind of performance boost under normal circumstances, maybe you should just consider tossing in a nitrous kit.
The approx 150lbs of batteries and drive motor ain't going to help matters either.
Heh, thanks for the non constructive critism. Like I've said...
It works, there's no question, my alternator puts out 200 amps as opposed to the typical stock 90amps. So I have an extra 100 amps+ of potential unused FREE energy . I know parasitic lag from the alternator exists but we are only drawing less than 40amps (to turn the motor)(P= I x V therefor 375 = 12 x X therefor X = 31 amps) so my car runs off 70 MAX when idling so in reality I would have 130 amps that could safely be consumed (in spurts (non-continous)),.
We are talking like a nos system that is turned on when needed using a variable speed control system that could even be tied into tps (most likely controlled through tuning software via tps sensor anyway lol) (BTW alternator was already replace because my stock one is 800 dollers (new at honda)) so needless to say the high end performance one (200amp) was the logical choice for around 400$. Looks way better too all chromed up.
As far as weights concerned total weight in parts including the two odessy marine batteries, compressor housing/wheel, inlet filter, botv, air bypass valve, and my current motor(prototype chosen 24V dc motor 1/2 hp) is 51 lbs and that's not even including what I would take out by removing my single 12vdc huge typical battery. This also excludes what intercooling setup I will implement but it won't be much at all in weight. I've removed my stock intake resonator (20 lbs) and have done lots of weight reduction so added weight is not an issue. Cost IS however and all these systems you guys are recomending are thousands upon thousands of dollers.
So again, please keep responses to ways to turn this shaft, either a 24 v system where I can maintain my 12v dc car system, or a 12V dc motor that occupies less space than approximately 10" square but can put out around 5000-8000 rpm with a wattage around 375 (1/2 hp approx.).
Danger, and your reasoning of the belt driven supercharger is why I don't go those routes. Those draw HUGE parsitc lag and are costly therefor arn't cost affective. We are talking numbers here. Those systems cost 3000 dollers to give you maybe 100 horse MAX, and the system I have assembled is less than a 1/3rd of that and will put out 60 hp on a 2.3L engine 2200 approx cc engine. The turbo is more efficient (the cheap one I bought isn't, its probably 65% (new ones for 600$ are like 85% efficient) but I got mine for 40$ (compressor side of turbo)
Chroot. As far as heat transfer between exhaust side and compressor side there is "tonnes" that get transferred but it depends on your turbo system. If its oil cooled, or water cooled, and if it has an intercooler (upon a million other factors like Pressure ratio etc), will factor how much heat is transferred to the actual intake. I guess it depends on how much money you got. If you can sink $5,000 into a turbo system you can incorperate a wicked Water cooled turbo, with a intercooled system and get an efficiency of 85% or maybe higher (I don't know how efficient they can be, being the new technology they come out with on a daily bases). But If you don't have 5000 dollers, then your whole system is going to be actually around 60%-70% efficient range where as my system would be above 80% efficient (in comparison to how much power is produced to how much is used to generate it).
So either way its belt driven (which kinda sucks but direct drive will not get my gear ratio high enough to spin the impeller 50000 rpms unless I could find a gear motor that's gearing increases the rpm output by 10x), so I know I have losses there but that's it.
All your input is valuable either way, just like I said if you could focus on what power supply (how I could adapt a 24V dc supply charging off my alternator, while maintaining my stock 12Vdc car because the full 24V dc conversion is expensive) and If you know where I can get a good half horse 12Vdc motor that can spin at more than 5000 rpm, chime in. Thanks!
I'm afraid that I'm going to have to bail on this one. I've expended what little knowledge I had of the subject. Good luck with the project. I'll keep reading to see how it goes.
thanks man!
Would anybody be able to suggest a forum that is specific to dc power/motors?
As above states. I was wondering if anybody here had any suggestions to a forum that would be better suited for dc motor/ dc supply theory/physics?
thanks again for any help anybody may provide!
Im a little confused. If I understand this correctly you want to have a 24V supply and convert that two 12V. You want a switching power supply/DC-DC converter. Here we go:
http://www.evparts.com/prod-DC1431.htm" Unfortunately, that won't work for your application unless your chassis isn't the ground.
No, the opposite. I want to run a 24V dc motor off a 12V dc power system. I'm sure if they make those, they make step-up versions (convert 12 vdc power to 24vdc)
Thanks!
those are a touch pricey, but the idea is what I'm looking for.
Okay, I have been looking for a 24vdc source as well, I might have to convert over to a 24vdc generator out of a (Voltswagon bug) I meant to say Humvees or use a dc to dc converter which the amps are not sufficient enough to put out 400amps. My application is a little differnet but the same research as yours. I thought about bypassing the internal regulator or beafing up a dc to dc converter which do exist but very costly at leat $800 each. I will search for the website I found them at and post it later.
My recommendations is to replace your alternator to a generator out of a (VW bug) I meant to state HV's Humvees that runs a 24vdc system. After doing that use a 24vdc to 12vdc converter for the rest of the car.
Or bypass your regulator in the alternator and upgrade it using an external 24vdc regulator. then add a 24vdc to 12vdc converter for the rest of the car. This way will cost a little more.
My issue is my application requires 400+ amps. I am trying to figure out which way I want to go: remove internal exciter, regulator, and diodes to convert it over to alternating current then convert back over to direct current and then use a step down transformer to convert to 24volts. Or just do what I stated previously. I already bought a 200amp alternator for around $400 and don't want to spend another $400 on a high amp 24vdc generator/alternator. I might just buckle down and buy the 24vdc high amp gen/alt. I know this is two years too late but still worth a shot.
DC to DC Converter
http://zahninc.com/su1.html?gclid=CLC_1tSz36QCFRiAgwodPXDXlw
High amp 24vdc generators
http://www.zena.net/htdocs/alternators/altspec2.shtml#Top
I don't know why I stated Voltswagon, I was thinking Humvees and my hands were typing vw bug.
Go to your local Chevy dealer and ask about a power steering motor from a Cobalt. There is a recall on them right now and they are replacing all of them. If you're lucky you might be able to get one or two of the take-offs for free. It's a 12 motor protected by a 60 amp fuse. I'm not sure about the rpm/torque characteristics but it's got to be ballsy enough to take the place of a power steering hydraulic system because that's what it does.
  • · Replies 26 ·
  • · Replies 68 ·
16K
33K
18K
66K
