What is the Trajectory of Four Rockets in a Square Formation?
The discussion revolves around a physics problem involving four rockets positioned at the corners of a square, each aiming at the rocket in front of it. The rockets maintain a constant speed and are expected to follow spiral trajectories towards the center of the square rather than moving in straight lines. Participants clarify that the rockets continuously adjust their direction to point at the next rocket, creating a dynamic where their paths are always at a 45-degree angle relative to the radial towards the center. The conversation emphasizes the need for differential equations to describe the motion and the symmetry of the setup. The problem highlights the intriguing nature of motion in a constrained formation, leading to a spiral trajectory.
onsem
Hi,
first I want to apologize for my english. I'm not from an English speaking country and I have to practise.
I have a quite interesting physical assignment for you. I was trying but I still can't solve it.
If you would have an idea or if you would know how to solve it please let me know. I will be very grateful.
So, how the assignment sounds:
We have four rockets in each corner of the square one. Each rocket aims on the rocket in front of it. Length of square side is a. All the rockets starts at the same moment. They have constant speed (no acceleration). I want to work out their trajectories and how long they will fly until they explode?
Picture (before the start):
picture is on this site:
http://forum.matweb.cz/viewtopic.php?id=7793
(00 - rocket pointed on the other one)
Picture (general trajectories:
r - a,b,c,d - rockets
a,b,c,d - trajectories
P.S.: I apologize for my painters and language abbilities
If they are not accelerating, why then are they not moving in straight lines but in spirals toward the center?
Do you mean that the rockets keep turning so their instantaneous speed is always pointing to the position of the next rocket, while its magnitude stays the same?
Each rocket is heading on the rocket in front of it (in every moment) and each one has the same speed v as the other three rockets (they also started at the same moment so they have to have the same trajectory turning into the centre of the square).
I hope that I have ansanswered on your question.
Welcome to PF!
Hi onsem! Welcome to PF! :wink:
Call the positions r1 r2 r3 and r4
what is the differential equation which says that each one has constant speed v towards the next one?
and what is the equation which says that each one (because of symmetry) is 90º round from the next one? :smile:
The speed of the rockets doesn't matter, just the direction. Relative to a radial from the center of the paths, the direction is always 45 degrees inwards (or outwards if going backwards), of perpendicular to that radial, which creates a spiral. Somehow you're supposed to get the insight that the (outwards) direction of curve, {tan}((r\ d\theta)\ /\ dr) \ =\ \pi/4 (or any constant angle for this type of spiral), and continue from there.
  • · Replies 32 ·
9K
