bob012345
- 1,139
I understand there is no general formula for higher order figures inscribed in a circle in terms of the radius as a function of side lengths. At least not without high powered math and special functions. But still we can use the equation above to numerically solve it for higher order with the caveat that for an ##n##-sided figure, the longest side is less than the sum of the other sides. ##c_{n}<\sum _{i=1}^{n-1}c_{i}##
We can start with the general formula under the assumption the given sides make a closed figure inscribed by a circle.
##\sum _{i=1}^{n}\arcsin \left(\frac{c_{i}}{2R}\right)=\pi ##
Depending on the side lengths, there are two possible cases for the center of the circumscribed circle:
##A=\sum _{i=1}^{n-1}\arcsin \left(\frac{c_{i}}{2R_{\text{crit}}}\right)##
Then,
We can then use a solver (I used Desmos) to compute the intersection of two functions as follows;
- Polygon includes the center of the circle (Center Inside)
- Center of the circle lies outside the polygon (Center Outside)
Then,
- If ##A >\frac{\pi}{2}##: The center is inside the polygon.
- If ##A < \frac{\pi}{2}##: The center is outside the polygon.
- If ##A = \frac{\pi}{2}##: The longest side ##L## is a literal diameter of the circle.
- If Case 1 (Inside):
##y=\sum _{i=1}^{n}\arcsin \left(\frac{c_{i}}{2R}\right)\quad \text{and}\quad y=\pi ## - If Case 2 (Outside):
##y=\sum _{i=1}^{n-1}\arcsin \left(\frac{c_{i}}{2R}\right)\quad \text{and}\quad y=\arcsin \left(\frac{c_{n}}{2R}\right)##
(Where ##c_{n}##is the longest side)
