Calculating Intensity at a Point in a Diffraction Pattern
The discussion revolves around calculating the intensity of light at a specific point in a diffraction pattern created by a single slit. The setup involves a 0.4 mm wide slit and monochromatic light of 546.1 nm, with the screen positioned 120 cm away. The original poster is attempting to determine the fractional intensity at a point 4.1 mm from the central maximum.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using trigonometric methods to calculate the angle to the point of interest and apply it in the intensity formula. There are questions about the correct interpretation of the angle and the proper use of the intensity equation.
Some participants have provided guidance on the appropriate formula to use, suggesting that the angle should be expressed in radians. There is ongoing exploration of how to relate the angle to the intensity calculation, with some confusion about the terms involved, particularly regarding the variable I0.
Participants are navigating through potential misunderstandings of the equations and the physical meanings of the variables involved. There is a focus on ensuring that calculations are performed correctly, particularly in terms of unit consistency and the assumptions made in the setup.
prolong199
I have the follwoing question for prep for a lab, i have tried to work out the answer but i am struck with trying to work out the intensity at a certain point, in this case 4.1mm from the central maximum. I have tried using trig to calculate the angle to the point using trig then using
I=I(sin(angle/2)/(angle/2) all squared. Am i on the right track?
"..A diffraction pattern is formed on a screen 120 cm away from a 0.4 mm wide slit. Monochromatic light of 546.1 nm is used. Calculate the fractional intensity, I/I0 at a point on the screen 4.1 mm from the centre of the principal maximum..."
could some please point me in the right direction, thanks
Welcome to the forums.
This is just a matter of plugging in the numbers in an equation. The equation contains a sine squared over a certain quantity squared. Do you know this formula?
sorry i forgot to add it in the first place, yes i think it is the one is added to my question?
well, it depends what you mean by ''angle over 2''. What is the expression for your angle?
The angle over 2 should be equal to {\pi a y \over L \lambda}
I worked out that the angle is 0.191 degrees, substituting into the equation i get 0.0175*I, do i then multiply by 546.1nm?, I am confused about the Io
Your equation was incorrect. It should not be sin^2(angle/2)/(angle/2)^2...(this equation is the right one if by ''angle'' you mean the *phase difference* between the two waves but that is not what you are doing here).
I gave you a formula that would not require to calculate the angle, but if you want to, then use the formula
I = I_0 {sin^2( {\pi a sin( \theta) \over \lambda}) \over ({\pi a sin(\theta) \over \lambda})^2
where theta is the angle you just calculated.
A word of caution: you should put everything in radians and make sure your calculator is in radians mode when you use this formula.
Since you want the ratio I/I_0, you just need to calculate the right side of the equation and divide by I_0 so it will disappear from your result.
I used trig to work out the angle from the source to the point 4.1mm from the maximum. I then used this angle in the equation.
That's perfectly fine. But when y is much smaller than the distance to the wall, you can also use an equation in terms of y directly. Just replace the sin(\theta) in the equation I gave before by y/L.
In any case, if you use the expression I gave in my previous post you should get the answer you are looking for.
  • · Replies 34 ·
