How Does Path Difference Affect Interference Patterns in Light Waves?
The discussion focuses on calculating the path difference (∆s) for light waves at specific points in an interference pattern created by two slits. At Point P, the path difference is 0 nm, indicating it is a maximum. At Point Q, the path difference is 699 nm, representing the next maximum. Point R, being a minimum, has a path difference of approximately 1048.85 nm, which is the sum of the wavelength and half of it. The calculations emphasize the importance of understanding the relationship between path differences and interference patterns.
luke949
http://img5.imageshack.us/img5/4605/lchuynh177setphys52awee.png
The figure shows the interference pattern that appears on a distant screen when coherent light is incident on a mask with two identical, very narrow slits. Points P and Q are maxima; Point R is a minimum. The wavelength of the light that created the interference pattern is λ = 699 nm, the two slites are separated by rm d = 6 μm, and the distance from the slits to the center of the screen is L = 80 cm . The difference in path length at a point on the screen is ∆s = |s1 − s2|, where s1 and s2 are the distances from each slit to the point.
1. What is ∆s (in nm) at Point P?
2. What is ∆s (in nm) at Point Q?
3. What is ∆s (in nm) at Point R?
da=sqr(L^2+(D/2+d/2)^2)
db=sqr(L^2+(D/2-d/2)^2)
I know the answer to the first problem is 0.
But i tried plugging in da=sqr(80^2+(699-3)^2) and I am getting it wrong. I tried converting all the units to nm, but then the equation just turns into sqr(80nm^2) because the second term turns into a number close to zero.
No geometry/trigonometry is necessary.
Think about the requirements for those particular maximum and minimum lines!
Hmmmm I am almost positive that the pythagorean Theorem must be used. I can't really see it any way. what do you mean by requirements?
Is the answers 1) 0, 2) 699nm, 3) 1048.85? I believe that the the center is a maxima and Q is the next maxima so that is one full wavelength. R is a minima right after the first maxima so it is 699+349.5 = 1048.85nm. Please get back to me thank you.
luke949 said:
is the answers 1) 0, 2) 699nm, 3) 1048.85? I believe that the the center is a maxima and q is the next maxima so that is one full wavelength. R is a minima right after the first maxima so it is 699+349.5 = 1048.85nm. Please get back to me thank you.
exactly! They ask for path difference, and the maxima and minima occur for specific path differences
EDIT: I am in East Coast Australia, so time differences will explain any delay in this response.
