Intergrator/Differential Op-Amp Frequency
  • Thread starter Thread starter big_tobacco
    Frequency Op-amp
The discussion focuses on the impact of frequency on the output amplitude of integrator and differentiator op-amp circuits. Integrators function as low-pass filters, while differentiators act as high-pass filters, leading to frequency-dependent output responses. The op-amp model, such as the 741, has a frequency range limit of 20 KHz, which affects the output when subjected to square wave inputs due to harmonic components. As frequency increases, the output amplitude of the integrator decreases, while the differentiator produces narrower pulses that may not reach full amplitude at higher frequencies.
  • Understanding of operational amplifier (op-amp) principles
  • Knowledge of integrator and differentiator circuit configurations
  • Familiarity with frequency response and filtering concepts
  • Experience with square wave signal characteristics
  • Study the frequency response of op-amps, focusing on models like the 741
  • Learn about the mathematical equations governing integrator and differentiator circuits
  • Explore the effects of harmonic distortion in square wave signals
  • Investigate practical applications of op-amp filters in signal processing
Electronics engineers, students studying circuit design, and professionals working with signal processing who seek to understand the behavior of integrator and differentiator op-amp circuits under varying frequency conditions.
big_tobacco
Hello,
I'm baffled as to why different frequencies affects the output (amplitude) of a integrator and differentiator op-amp circuit.
I'm using a variety of frequencies (100 Hz - 10Khz), with a fixed 1V square wave input? Why does the frequency cause a change in the amplitude?
This isn't a homework question, I work with simple op-amps all the time and it's about time that I should know the principles.
Any help would be greatly appreciated.
Regards
Also another factor could be the op-amp's frequency range.
For example, a 741 works up to 20 KHz,
but a square wave is composed of odd order harmonics. So if you apply a 10 KHz square wave, then there is a frequency component at 30 KHz, which would likely be killed by the op-amp like the 741 - and hence signal amplitude is reduced.
Another way to look at this is that with a square-wave input, an integrator should give a triangular-wave output. Thus the output amplitude is inversely proportional to frequency. Provided that the fundamental frequency of the square wave lies well within the bandwidth of your op-amp, the practical result should be a fair approximation to this.
The situation for a differentiator is more complicated. In fact, a perfect square-wave input applied to a perfect differentiator would give an output consisting of infinitely narrow and high pulses. In the real world, a square-wave will have limited edge speeds, and an integrator will have limited maximum output amplitude and limited slew rate.
If the frequency of a square-wave input to a practical differentiator is increased from a low value, the output will most likely be a series of alternating narrow pulses of roughly constant amplitude, which get closer in time as the frequency increases. If the frequency is increased sufficiently, there will not be enough time for each pulse to reach full height, and the output amplitude will begin to drop off if the frequency is increased further.
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 31 ·
  • · Replies 50 ·
  • · Replies 33 ·
