Intermediate algebra , Natural logarithm question
The discussion centers on understanding the equation e^ln(x) = x, which stems from the definition of the natural logarithm as the inverse of the exponential function. Participants clarify that ln(x) represents the exponent to which e must be raised to yield x, reinforcing that e^ln(x) simplifies directly to x. They emphasize the importance of grasping logarithmic properties, such as ln(e^a) = a, to comprehend why this relationship holds true. Some contributors suggest using relatable analogies to help students connect with the concept more effectively. Ultimately, the consensus is that understanding the inverse nature of these functions is key to mastering the equation.
popsquare
Hello everyone, I do not understand how:: e raised to ln of x = x ?
this notation might make more sense:: e^ln x=x ?
Thanks for the help.
Mathematics news on Phys.org
By definition, ln(x)=a means e^a=x (i.e. ln is the inverse of e^x).
Obviously though, it seems like you're not using that definition (I hope...).
How are you defining ln(x)?
ln x = e ^ some number. we just use a calculator. we made a list in class of these ones, but they are simple.
ln e^2=e
ln e^x=x
No... it's the other way around
ln(e^x) = x
Note ln(e^2) = 2, not e.
Anyway, the definition of natural log is ln(e^x) = x (well, the definition you should be working from)
The natural log has a base of e, so if you raise e^ln(x), it will always just equal x.
e^{ln_{e}(x)} = x
its for the same reason the father of the man whose father is john, is ...?
If f(x) is a bijection (i.e, an onto, 1-to-1 function), then there will exists another function g(x), such that: g(f(x)) = x, and f(g(x)) = x, we denote that function g(x) by f-1(x), and call it the inverse of f(x) (i.e a function which does the reverse of f(x)).
Say, if we have: f(a) = b, then we'll have g(b) = a. So we have: g(f(a)) = g(b) = a, and f(g(b)) = f(a) = b.
ex has the inverse ln(x) (i.e, we define ln(x) to be the inverse of ex). So, if f(x) = ex, then f-1(x) = ln(x).
So, we have: f(f ^ {-1} (x)) = e ^ {f ^ {-1} (x)} = e ^ {ln (x)} = x, as f(f-1(x)) = x
And f ^ {-1} (f(x)) = \ln(f(x)) = \ln (e ^ x) = x, as f-1(f(x)) = x
perhaps it is better to first understand what a log is. A log is an exponent. log_2{8} means the exponent on 2 to get 8. (3)
ln means log base e. So, ln(x) means "what is the exponent on e to get a value of x?" example ln(5) means "what is the exponent on e to get a value of 5?" In other words, e^? = 5.
So, when you raise e^[ln(x)], that means e to the power: [the power on e to get x].
So, e^[ln(5)] means raise e^(power that when e is raised to that power, the result is 5.)
I just had to explain this to my calculus class.
We know that e^(ln x) must be some number, call it q. So e^(ln x) = q.
If we take the natural logarithm of both side of the equation we have
ln (e^(ln x)) = ln q.
Hopefully, we are convinced that ln (e^a) = a by the laws of logarithms. If not, here it is quickly.
ln (e^a) = a ln e = a*1 = a
So ln (e^(ln x)) = ln x.
Thus we have ln x = ln q, which might convince you that q = x.
If not, we continue
ln x - ln q = 0, so ln (x/q) = 0. Then, by the definition of logarithm (as an inverse function), x/q = e^0 = 1, So x = q.
Putting this back in the original equation, we have e^(ln x) = q = x.
(We must include the caveat that x > 0).
How, then, have you defined ln(x) in your class?
I see your point. If ln x = a means e^a = x, then clearly, by substituting a into the second equation we get the result e^(ln x) = x.
However, some students need a bit more convincing that the "complicated" formula e^(ln x) = x is right. They accept the definition, in principle, but do not always see connection to the results. By bringing it down to the situation where ln(x/q) = 0, they were then able to make the connection that x/q=1.
BTW, as stated in my post, I use the inverse function definition of the natural logarithm. Sorry for the confusion.
This might seem a little silly but it really seems to work. When a student says that they can't understand why e^(ln x) = x is correct this is what I sometimes do. I say that I will explain it to them, but first they must explain something to me.
I then tell them that I've just encounter \sqrt{\cdot} for the first time and I don't understand it (they know I'm joking) and that they must explain to me why it is that for any positive number "x" that \sqrt{x^2} = x.
It's quite interesting just how often in that in the process of explaining this (or thinking up an explanation) that they suddenly claim to now understand the e^(ln x) thing. I guess it's just a matter of putting it into a 1-1 relation with a problem that they already understand.
13K
