Internal combustion engine calculation questions
The discussion revolves around various calculation questions related to internal combustion engines, specifically focusing on engine cycles, piston speed, and volume change during crankshaft rotation. The scope includes homework-related problems requiring technical understanding of engine mechanics and kinematics.
  • Homework-related
  • One participant asks for help calculating the number of engine cycles completed every second based on the crankshaft's RPM, noting a previous incorrect attempt.
  • Another participant points out that the original calculation was for revolutions per second, not cycles, and suggests looking up how a 4-stroke engine operates to clarify the relationship between revolutions and cycles.
  • There is a question regarding the velocity of the piston when the crankshaft is at a specific angle, with one participant questioning why the velocity would not be zero if the piston only moves in the y-axis.
  • Multiple participants assert that the correct relationship between RPM and cycles per second is RPM divided by 2, not 4, emphasizing that 1 cycle equals 2 revolutions.
  • One participant expresses a need for further assistance with additional questions after receiving clarification on the first question.
  • A mentor reminds the original poster to follow the Homework Help Template and show their work, indicating that the thread may not meet the forum's guidelines.
Participants generally agree on the relationship between engine cycles and revolutions, specifically that 1 cycle equals 2 revolutions for a 4-stroke engine. However, there is some confusion regarding the calculations and the correct application of the formulae, leading to multiple viewpoints on how to approach the problems.
Participants have expressed uncertainty about the correct application of formulas and the assumptions underlying the calculations, particularly in relation to the geometry of the engine and the axes of motion.
Students studying internal combustion engines, mechanics, or related fields who are seeking assistance with homework problems involving engine calculations.
Fawzi Da
< Mentor Note -- Poster has been reminded to use the Homework Help Template and show their work on schoolwork problems >[/color]
Hello everyone I have some questions on engine calculations that I need help in please.
1) A reciprocating internal combustion engine operates on a 4 stroke cycle. If the engine's crankshaft is rotating at 5,985 rev/min, calculate the number of engine cycles completed every second
(note that I tried 5985/60 and that gave me a wrong answer)
2) An engine has a crank radius of 41mm. If the engine's crankshaft is rotating at 2131 rev/min the calculate the mean piston speed (m/s)
3) For an engine:
-Operating at speed of 2151 rev/min
-Having a crank radius of 41 mm
-Having a connect a connecting rod length of 136 mm
When the crankshaft has rotated 84 degrees from top dead centre, calculate the velocity of the piston, u (m/s), in the x-axis direction.
(why isn't the velocity 0 m/s since the piston only move in the y axis?)
4) An engine has the following geometry:
-A bore of 75 mm
-A stroke of 70 mm
-A ratio of connecting rod length to crank radius of of 3.8 m/m
Calculate the rate of change of volume (m^3 / rad) when the crankshaft has rotated -30 degrees from top dead centre
Thank you in advance
You calculated the number of engine revolutions per second. The question asked for the number of cycles per second. Look up how a 4 stroke works and find out how many revolutions there are per cycle. It's not 4.
Perhaps its flat 4 or V8 ? Is there a diagram to go with the question? Otherwise how do you know which is the x and y axis?
I thought about it. I believe the correct answer is RPM/4/60 to get cycles per second.
May I ask help for the other questions as well?
It's not 4.
CWatters said:
It's not 4.
Sorry sorry I meant RPM/2/60
That's better :-).
1 cycle = 2 revolutions = 4 strokes
CWatters said:
That's better :-).
Thanks :) can you please provide me with help for the other questions please?
You were warned in your previous thread (now deleted) to show your work and post using the Homework Help Template. You re-posted your questions and only showed a small amount of work on some of them. That is not acceptable here.
Post one question per schoolwork thread, and use the Homework Help Template that you are provided to show your work on the problem. This thread is closed.
  • · Replies 32 ·
  • · Replies 49 ·
9K
