How is kinetic energy and momentum conserved in an internal explosion?
In the discussion about the conservation of kinetic energy and momentum during an internal explosion, participants clarify that the initial momentum is zero since the object is at rest before the explosion. They establish that while momentum is conserved, kinetic energy is not, as the explosion releases energy, resulting in a total kinetic energy of 7500 J post-explosion. The conversation includes calculations to determine the kinetic energy acquired by each piece after the explosion, with one piece having 1.5 times the mass of the other. Participants express confusion over the timing of kinetic energy and momentum conservation, but ultimately agree that momentum remains zero before the explosion and balances out after. The final kinetic energy values for the pieces are calculated to be 2000 J and 5500 J, respectively.
pb23me
an internal explosion breaks an object, initially at rest, into two pieces, one of which has 1.5 times the mass of the other. If 7500 J were released in the explosion, how much kinetic energy did each piece acquire.
K1+K2=7500J
3/2mvi+mvi=3/2mvf+mvf
p2/2m=KE
I am not sure exactly when kinetic energy or momentum begin and end in the conservation equations. Does kinetic energy begin at zero and end right after the explosion? Does momentum begin at zero as well? and where does it end? This is a big source of confusion for me.
hi pb23me! :smile:
momentum is conserved in all collisions or explosions (reverse collisions!)
energy, obviously, is not conserved in an explosion, but you're told that the initial KE is 0, so the final KE must be 7500 J :wink:
Well it is initially at rest, so the initial momentum is zero.
the final momentum will be mv1+(1.5m)v2. You can now form the equation for conservation of momentum
Now energy is is also conserved so 7500 = KE1 + KE2
KE1 = (1/2)mv12
Hi tiny tim, i just read something about this that's seems to be a contradiction... In an explosion the initial momentum is zero, the pieces fly in opposite directions so momentum is conserved. Well then how does that work out for the conservation of momentum equation m1vi+m2vi=m1vf+m2vf... it starts with zero and ends with some amount? How is that conservation. Also what is the final momentum is it right after the explosion? KEf is that right after the explosion as well?
or rockfreak thanx.
hi pb23me! :smile:
momentum (unlike energy) is a vector, so the final momentum can (and does!) still add to zero :wink:
it doesn't matter …
momentum is always conserved anyway,
and energy will only fail to be conserved during the explosion itself :smile:
Ok so 1/2mv12+1/2mv12/2.25=7500J
3.25mv12=33750
1/2mv12=5192.3J
1/2mv22=2307.7J
3.25mv12=33750
1/2mv12=5192.3J
1/2mv22=2307.7J
sorry, I'm following neither the logic nor the arithmetic :redface:
where is the conservation of momentum? :confused:
try using your KE = p2/2m equation :smile:
oops... ok v2=-3/2v1 so [(3/2)mv1]2/2m+(mv2)2/2m=7500J so plugging in v2=-3/2v1 i get 15mv12/8=7500J
KE1=2000J
KE2=5500J
why are the masses on the bottom the same?
why are the momentums on the top different? :confused:
the masses on the bottom are supposed to be 3m and 2m. I had the right masses in my calculation just forgot to write that on here. And for the momentums on the top it should be 9/4(m)v12 for the first and (mv2)2 for the second
:smile: :smile:
oh that's hilarious!
i'm going to bed now :zzz:
see if you can tidy it up by the morning! :wink:
[(3/2)mv1]2/(3/2)2m+(mv1)2/2m=7500J
so 3mv12/4+mv12/2=7500J
15mv12/8=7500J
mv12=4000J
so 1/2mv12=2000J
1/2mv22=5500J
I don't understand where my error is at?
15mv12/8=7500J
nooo :redface: … 5mv12/4=7500J :wink:
oh ok... That was from an earlier miss calculation that i didnt go back and check...thanx
  • · Replies 18 ·
