Interpret this probability distribution
The discussion revolves around interpreting a specific probability distribution related to the negative binomial distribution and its connection to the geometric distribution. Participants are examining the mathematical expression involving binomial coefficients and probabilities, seeking to clarify its implications and relationships.
  • Participants explore the interpretation of the given probability distribution, questioning its relationship to the negative binomial and geometric distributions. There are attempts to derive results using the binomial theorem and discussions about the implications of summing probabilities over trials.
The conversation is active, with participants providing different perspectives on the interpretation of the distribution. Some have offered analytical approaches, while others express uncertainty about the outcomes of their calculations. There is no explicit consensus, but productive dialogue is ongoing regarding the mathematical properties involved.
Participants are grappling with the implications of the distribution in the context of fixed successes and varying trials, and there are mentions of specific cases and computations that illustrate their points. The discussion reflects a mix of confusion and insight regarding the mathematical principles at play.
hoffmann
i took an exam today and was sort of stumped by this question. pls take a look, thx!
how do i interpret this probability distribution:
\sum_{k=r}^\infty \binom{k}{r}p^k(1-p)^{k-r}
where r is the number of successes, p is the probability, k trials.
by looking at it, it seems like it's similar to a negative binomial distribution once you pull out a k/r. if you do some math after pulling out the k/r, it seems like it is the expected value of a geometric distribution. is this distribution saying that a negative binomial divided by the number of successes r means there is only one success, which is geometric?
as in, what does this distribution equal?
It's just summing up binomial random variables. We're summing over k - the number of trials. r is fixed so we are summing the probabilities that we have r successes for k = r,..., infinity trials.
Hmm, let's take an analytic stab.
Using the binomial theorem,
(p + (1 - p))^{k} = \sum_{i=0}^k \binom{k}{i}p^{k}(1-p)^{k-i}
so
1 = 1^{\infty} = (p + (1 - p))^{\infty} = \sum_{i=0}^\infty \binom{k}{i}p^{k}(1-p)^{k-i} = \sum_{i=0}^{r-1} \binom{k}{i}p^{k}(1-p)^{k-i} + \sum_{i=r}^\infty \binom{k}{i}p^{k}(1-p)^{k-i}
finally we get
\sum_{i=r}^\infty \binom{k}{i}p^{k}(1-p)^{k-i} = 1 -\sum_{i=0}^{r-1} \binom{k}{i}p^{k}(1-p)^{k-i} = 1 - P({X < r})
Where X is a binomial random variable with parameters k, p.
i understand the first part of your explanation. where did the "Hmm" part come from? is this an alternative explanation?
Yeah sorry I was wasn't finished editing it. Its confusing no doubt though :smile:. I guess it's the complement that we will have less than r successes in k trials, but I'm not sure.
hm...i thought your first answer made sense. that this is equal to simply 1.
Yeah i thought that made sense too but "doing the math" gave a different answer.
Think about the same scenario again (a fair coin, look for 8 successes, k trials). Sum up the probabilities that we get 8 successes after k flips from k = 8 to infinity flips. Should this sum be 1? I have no idea so I'll resort to computation:
8 trials:
\sum_{i = 8}^8 \binom{8}{i}\left(\frac{1}{2}\right)^{8} = 0.003906
9 trials:
\sum_{i = 8}^9 \binom{9}{i}\left(\frac{1}{2}\right)^{9} = 0.019531
20 trials:
\sum_{i = 8}^{20} \binom{20}{i}\left(\frac{1}{2}\right)^{20} = 0.868412
50 trials:
Sum is .999999
Turns out it does come out to 1 and I was initially right.
Well my math up there is right too. In the special case where r = k (the number of trials). P(X < r) is P(we have r successes in less than r trials) = 0. So the math gives the same result of 1. Hope that helped!
let me sum it up analytically:
\sum_{k=r}^\infty \binom{k}{r}p^k(1-p)^{k-r} = (p + (1 - p))^{n} = 1^n = 1
where r = 0,1,2...n
the first step is a direct result of the binomial theorem.
Not exactly. You did not use the binomial theorem correctly. The summation must start at 0. Also n = \infty.
