Interpretation of distance mentioned as degrees
The discussion clarifies the concept of angular diameter, specifically regarding the Sun and Moon as viewed from Earth. It establishes that the Sun and Moon each have an apparent angular diameter of 0.5 degrees when observed from Earth. The term "angular size" is defined as the angle subtended at the observer's position by the diameter of the celestial object. The confusion arises from the phrasing of statements regarding apparent separation, which should focus on angular measurement rather than distance.
  • Understanding of angular diameter and its significance in astronomy.
  • Familiarity with basic geometric concepts related to angles and vertices.
  • Knowledge of observational astronomy terminology.
  • Ability to interpret visual representations of celestial objects.
  • Research the concept of angular diameter in astronomy.
  • Explore the differences between angular size and physical distance in celestial observations.
  • Learn about the methods used to measure angular diameters of celestial bodies.
  • Investigate the implications of angular size on astronomical observations and calculations.
Astronomy enthusiasts, educators, students studying celestial mechanics, and anyone interested in understanding the visual perception of celestial objects from Earth.
JC2000
1. Consider the sun like a star at a distance of 2 parsecs. When it is seen through a telescope with 100 magnification, what should be the angular size of the star? Sun appears to be (1/2)° from the earth. Due to atmospheric fluctuations, eye cannot resolve objects smaller than 1 arc minute.
OR
Moon is seen to be of (1/2)° diameter from the earth. What must be the relative size compared to the earth?
I know that one parsec is the angle at the vertex which subtends an arc with length 1 AU.
What is the image that comes to mind/meaning behind the above statements where an objects is seen/appears 'to be (angle) diameter of the Earth?
My interpretation is that if the given angle is drawn with one object as the vertex then the diameter of the second object subtends the given angle.(?)
I think the statement is poorly expressed and confusing. "Sun appears to be 1/2° from earth" looks as if it means an apparent separation between sun and Earth for some observer, but it actually means that the sun, as seen from earth, has an apparent angular diameter of 1/2°. So does the moon. "Angular size" is the angle subtended at the position of the observer by the diameter of the object.
So the vertex of the angle is on the Earth (the observer) and the diameter of the Sun subtends and angle of 0.5 degrees...
Yes.
