Invariant mass problem, elastic collision
13 replies · 5K views · last reply
Silicon-Based
f
Question b:
Typed exam question 3 on elastic proton-proton collision in the laboratory, parts a and b, ending with the target result c^2 p^2 = mc^2(E_0 - mc^2) / (2 sin^2 a).
E2=c2p2+m2c4
We have c2pinitial2=E02-m2c4, and Ef2=c2p2+m2c4 for each outgoing proton. Combining those equations we get c2p2=Ef2-E02+c2pinitial2. I don't know where to go from here.
  • Typed exam question 3 on elastic proton-proton collision in the laboratory, parts a and b, ending with the target result c^2 p^2 = mc^2(E_0 - mc^2) / (2 sin^2 a).
Is this for part a) or part b)?
What principles are you going to apply in solving this problem?
b). I would refrain from using conservation of momentum since that is specifically mentioned in part c (which I didn't include in the picture), and here it asks to equate the invariant masses.
Personally, I would never not make use of conservation of momentum. If momentum is not conserved, then is there a unique solution? So, I would reason that you must make use of conservation of momentum.
In any case, what else is conserved?
When I use conservation of energy (Ef=(E0+mc2)/2) the algebra seems to lead nowhere.
Also, presumably, I should ideally not introduce any gammas.
It says the total energy of the proton initially is ##E_0##. Not the Kinetic Energy.
E0 is the total energy of the proton in motion, E0+mc2 is the total energy of the system, which is equally distributed between both protons after the collision.
Yes, of course. Anyway, what happens when you include conservation of momentum?
I get results like mc2(E0-mc2)=2γm2cos2(α)c2, where γ is of the protons after the collision. But again, I should be able to solve the question without introducing any gammas, but I don't see a way to apply conservation of momentum without doing so.
Yes, don't introduce gamma. You can relate momentum to energy and mass without gamma.
What about using ##p_0 = 2p \cos \alpha##? That's what conservation of momentum in the original direction should have given you?
I end up with $$c^2p^2=\frac{(3E_0+mc^2)(E_0-mc^2)}{12-16\sin^2(\alpha)}$$
Obviously, that doesn't look quite right. I suspect it's just your algebra.
Did you square the energy equation? After that it should be a couple of substitutions to get rid of the terms you don't want in the final expression. Note that you need to get rid of ##E_0^2##.
E02 doesn't cancel due to the factor of two in the equation of energy conservation. Getting sine out of cosine messes things up as well.
You'll need to post your attempt to see where you are going wrong. I get the expression in the question, so there is no mistake there.
