Inverse of a Piecewise Function
8 replies · 13K views
SpringPhysics
Find the inverse of
...{x...x =/= a1,...,an
f(x) = {ai+1...x = ai, i = 1,...,n-1
...{a1...x = an
I interchanged the variables x and y, but I am very confused as to how to solve for the rest. I don't understand how to find inverses if we aren't given an explicit formula. Can someone help please?
SpringPhysics said:
Find the inverse of
...{a1...x = an
It might help you to just list the ordered pairs for f. Then reverse them all and you should see a way to write f-1 as a formula similar in form to the formula for f(x).
All right. Thanks for your help.
Also, could I ask for help on finding inverses for the following?
f(x) = x + [x] (floor) and f(x) = x/(1-x2) for -1 < x < 1.
For the first function, there is no reversible equation for the floor operator, so could I state the inverse as simply {(x+[x],x) | (x,x+[x]) [tex]\in[/tex] f}?
Would it be possible to state that any x in f be a.b, where a is an integer and b is any real number?
Then
f(x) = a.b + a for a >= 0 and
f(x) = a.b + (a-1) for a < 0.
Then the inverse of f would be given by
f-1(x) = 1/2 (x + 0.b) for x >= 0 and
f-1(x) = 1/2 (x + 1.b - 0.(2b)) for x < 0.
For the second function, I interchanged the variables and obtains:
x(1-y2) = y
0 = xy2 + y - x
Using the quadratic formula, I got
y = (-1 +/- [tex]\sqrt{1+4x^2}[/tex])/2x, -1 < y < 1
How do I know whether to take the positive or negative?
HallsofIvy said:
You shouldn't take either one. If your calculations are correct, you are saying that this function is NOT one to one and so does NOT have an inverse.
I am not sure which function you are referring to, but for the second function, the question asked to determine f-1 (the inverse) for -1 < x < 1. Hence, the function is 1-1 for the specified interval. I am just not sure there is an intuitive reason why the positive root works but not the negative.
The floor function is not 1-1 so it does not have an inverse, but the question is f(x) = x + floor (x), so that the function is 1-1. However, I am not sure how to cleanly express its inverse.
EDIT: Never mind for the floor function. Can someone please explain the first function?
Are you talking about f(x) = x + [x]?
Try drawing the graph of f-1. You will see that its domain has gaps and the segments of the graph are translates of f(x) = x. Does that help?
Sorry, I meant f(x) = x/(1-x2)
When you interchanged x and y and solved for y you got:
[tex]y = \frac {-1 \pm \sqrt{1+4x^2}}{2x}[/tex]
One way you can tell you don't want the - choice is what happens as x approaches 0. The branch you want goes through the origin. If you look at
[tex]y = \frac {-1 - \sqrt{1+4x^2}}{2x}[/tex]
as [itex]x\rightarrow 0[/itex] you get a -2/0 form which indicates a vertical asymptote.
On the other hand if you let [itex]x\rightarrow 0[/itex] in
[tex]y = \frac {-1 + \sqrt{1+4x^2}}{2x}[/tex]
you get 0 as you can see if you rationalize the numerator and take the limit.
Another thing that is a bit more work is to observe that with the + choice you get [itex]-1\le y \le 1[/itex], which also tells you you have the right branch.
I see now. Thank you so much for your help!
