Undergrad Inverse of the sum of two matrices
The discussion centers on expanding the inverse of a matrix M = A + εB when A is not invertible. Participants explore the implications of using small perturbations to A, emphasizing the distinction between topological and algebraic properties. It is noted that while invertible matrices are dense in the space of all matrices, this approach may not preserve important algebraic characteristics like eigenvalues. The conversation also touches on the arbitrary nature of perturbations and their impact on maintaining algebraic integrity. Ultimately, the need for a closed form for the coefficients of M^-1 in powers of ε is highlighted as a key concern.
Luck0
Suppose I have a matrix M = A + εB, where ε << 1.
If A is invertible, under some assumptions I can write e Neumann series
M-1 = (I - εA-1B)A-1
But if A is not invertible, how can I expand M-1 in powers of ε?
Thanks in advance
Thanks in advance
I smell Zariski, my favorite topology. The first thing you should ask is: what for? As invertible matrices are Zariski-dense in the space of all matrices, a small variation of ##\varepsilon## should give you an invertible matrix ##M##. However, this process isn't stable for algebraic properties like eigenvalues, nilpotency or similar. Of course not, as we already changed the determinant in the first place. So what for is essential to answers. Are we interested in topological properties or algebraic properties? What's fine for the first might be a no-go for the second and vice versa.
Also commutation properties between ##A## and ##B## could play a role. In general, you'll always find an element ##X \in \{A+\delta \cdot I\,\vert \,\delta \ll 1\}## which is invertible.
I'm more interested in algebraic properties. In fact, I want a closed form for the coefficients of ##M^{-1}## in powers of ##\epsilon##. The problem is that in my calculation, if I make ##A \to A + \delta I##, I'll have to keep terms in ##\delta##, which is something I want to avoid, because it looks a bit like cheating
It is cheating, if you're interested in algebraic properties. But the ##\delta ## is arbitrary to some extend, so you can as well take an expression in ##\varepsilon##. I remember that Volker Strassen has had used similar concepts to generically determine the computational rank of tensors. Unfortunately I can't remember an exact citation. But the keyword here is "generic", which means most in a topological sense, and thus results in quantitave rather than qualitative statements.
As an example: the zero matrix isn't invertible, whereas all ##\operatorname{diag}(\varepsilon, \delta)## are, although they their distance from the zero matrix is arbitrary small. However, they have little algebraic properties in common.
I see. Thanks for the answers!
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 26 ·
