Inverse Problems in Scattering
  • Thread starter Thread starter Steve Drake
    Inverse Scattering
Dynamic light scattering (DLS) data presents an inverse problem where the challenge lies in determining particle sizes from their scattered spectrum. The forward problem is straightforward, but inverting the data to retrieve original sample properties is complex. Users are seeking mathematical methods and coding solutions, particularly in MATLAB, to develop their own inversion routines. Recommendations include specific papers and the CONTIN program, which can recover particle size distributions but may be complicated or slow for some users. Overall, the discussion emphasizes the need for accessible tools and methods in solving inverse problems in scattering.
Steve Drake
Hi Guys,
I am doing a bit of work with dynamic light scattering (DLS) data. It is one of the many areas of science where we encounter an inverse problem.
The forward problem is: For a known sized particle, calculate its scattered spectrum (that is easy). The inverse problem is: from the scattered spectrum, calculate the size(s) of the partcile(s) that made the spectrum (that is hard).
What I would like to know is how, given an experimental data set, do you invert that data set to get the original sample properties? I just read some books and they don't seem to go into the maths.
Any help would be greatly appreciated. I am pretty good at MATLAB and would like to code my own inversion routines.
Thanks
Science news on Phys.org
opticspcs said:
You can the simulated CONTIN program, (http://www.mathworks.cn/matlabcentral/fileexchange/6523-rilt ), it is relative simple. It can recover the particle size distribution fom dynamic light scattering data.
Best regards.
Hi mate,
thanks for the reply to my very old topic hah. I had a go at that cause the original CONTIN is too complicated for me to use. rILT seems to work but its very slow. I have been using other methods in the mean time.
Thanks.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
10K
