Investigation about the emission spectrum of Mercury
The investigation into the emission spectrum of mercury utilized a diffraction grating spectrometer in a controlled environment to observe spectral lines. The experiment revealed faint lines surrounding the prominent emission lines, particularly in the blue and red regions. These faint lines are identified as side lobes, which are a result of the diffraction grating's properties. The presence of these additional lines indicates that mercury has multiple emission lines beyond the most luminous ones, confirming the complexity of its emission spectrum.
  • Understanding of diffraction grating principles
  • Familiarity with emission spectra and atomic transitions
  • Knowledge of the Fresnel region in optics
  • Basic concepts of light pollution and its effects on spectroscopic measurements
  • Research the principles of diffraction grating and its applications in spectroscopy
  • Study the emission spectrum of mercury and its various lines
  • Learn about the Fresnel region and its impact on optical measurements
  • Explore advanced spectroscopic techniques to minimize light pollution effects
Students conducting physics experiments, educators teaching spectroscopy, and researchers interested in atomic emission spectra.
Zibi04
For our investigation, we used a diffraction grating spectrometer to observe the emission spectrum of mercury.
We conducted the experiment in a pitch black room to avoid any unwanted light pollution, etc.
Whilst conducting the experiment we observed a number of 'faint' lines surrounding each of the brightest emission lines. For example, several faint blue spectral lines were observed surrounding the blue spectral line with the greatest luminosity. You can see these here: http://imgur.com/a/6KsOh
I was wondering if what we observed was perfectly normally, and if there is a name for it as well as a good explanation to include in my report.
N/A
I have noticed that what we observed are somewhat similar to the following image of the Mercury emission spectra: https://i.stack.imgur.com/onjhd.png
There appears to be some sort of light with a lower luminosity in-between each of the bright spectral lines, especially the red. However, I don't know the meaning of this.
My Physics teacher is ill and has been on leave, and I have been unable to make contact with him. I asked the other physics teacher at my school and he was unable to explain our observations.
Any help would be much appreciated :) Thanks
My understanding is that a diffraction grating is equivalent to a uniformly illuminated antenna array.
Such an array has a succession of sidelobes each side of the main beam and these gradually get less as we move off axis. The Wiki reference below gives sidelobe levels as -13dB (intensity 0.05) for the first and-17dB (intensity 0.02) for the second.
I should mention that although this is the principle of the effect, for the optical case we are working very close to the array, in the Fresnel Region, so that these numbers will not necessarily be correct.
https://en.wikipedia.org/wiki/Side_lobe
Thanks for the reply :) This seems to support what we observed in the investigation. I just wanted to clarify whether these side lobes are what can be seen circled in the following image: http://imgur.com/a/BzJWL ?
My picture here is not very sharp and I cannot see the lines in a group of three (or five etc) as I was expecting.
It's difficult to assess without additional experimentation. If you used a lens to focus onto the entrance slit to illuminate much of the diffraction grating (giving the beam a healthy f #), or even illuminate more than a very small region on the diffraction grating, there are enough lines on the grating that you would not get secondary maxima that far away from the spectral line that are that prominent. ## \\ ## If you have no ghost reflections occurring in your spectrometer (e.g. reflections off of a detector window that cycle through again), my guess is that these are additional and much dimmer lines in the Hg spectrum that you are also observing. ## \\ ## Note: If the diffraction grating is used in the proper manner as a many-lined grating, where you use at least approximately100 lines on the grating (the beam incident on the grating should be at least 1/4" across approximately), any significant secondary maxima will be so close to the primary maximum that they basically become part of the primary maximum. ## \\ ## Editing...I don't have a copy handy of a Handbook of Spectroscopy, but as I recall, mercury does have quite a number of other emission lines besides the very prominent ones. (That normally is the case with these larger atoms=e.g. the emission spectrum of iron consists of many many lines.) Also, an additional bit of googling showed a couple of spectral images that were taken that show this is the case.
21K
9K
  • · Replies 26 ·
11K
