Involute curve in bevel gear teeth
  • Context: Graduate
  • Thread starter Thread starter hihiip201
    Curve Gear Teeth
The discussion centers on the function of involute profiles in bevel gear teeth. The user expresses confusion about how the involute shape maintains proper meshing between gears when they rotate away from the center position. A response highlights the existence of animations demonstrating involute gear meshing without interference, indicating that the design allows for consistent motion despite angular changes. The inquiry emphasizes the importance of understanding involute geometry in mechanical design.
  • Understanding of bevel gear mechanics
  • Familiarity with involute profiles in gear design
  • Basic knowledge of gear meshing principles
  • Experience with mechanical engineering concepts
  • Research the mathematical principles behind involute gear profiles
  • Explore animations and simulations of bevel gear interactions
  • Study the impact of gear tooth design on mechanical efficiency
  • Learn about gear interference and its prevention techniques
Mechanical engineers, gear designers, and students studying mechanical systems will benefit from this discussion, particularly those interested in the intricacies of bevel gear design and involute profiles.
hihiip201
Hi
I have always wonder about this. I understand the concept of bevel gear, but never quite see how the involute profile would function in a bevel gear.
assuming that there is a tooth(either of the driving or driven gear) located at the center between two gears ( where it has the greatest contact with another tooth)
say it is involute and still appear so to you when you look straight down, perpendicular to the face of the teeth (so your line of sight align with the teeth's face normal, and about 45 degree to the axis of the gears).
now, if we rotate the gear such that the teeth are no longer in the center, it will no longer be involute relative to you, or more importantly to the tooth of another gear that it is in contact with, so wouldn't this create interference or causes the driven gear to not move at constant speed (say the driving gear is moving at constant speed).
thank you
Mesmer8 said:
Hi, Not sure what the question is, but there is a lovely animation of involute profile toothed gears meshing without interference at http://en.wikipedia.org/wiki/Involute_gear.
Namaste,
Mesmer8
Hi!
thank you so much for the reply and link!
I guess my question is short is just " how does involute profile work in bevel gears?"
thanks!
