Why Do Irrational Numbers Exist?
The discussion centers around the existence of irrational numbers, particularly questioning the nature of their existence and what it means for a number to be well-defined. Participants explore philosophical implications, mathematical definitions, and the relationship between rational and irrational numbers.
  • Philosophical inquiry
  • Some participants question the meaning of "existence" in relation to numbers, particularly irrational numbers like sqrt(2).
  • One viewpoint suggests that irrational numbers exist to fill gaps between rational numbers, while another argues that all numbers are constructs.
  • A participant raises the issue of well-definedness, asking how much information is needed about a number for it to be considered well-defined.
  • Concerns are expressed about the reliance on decimal representations to define numbers, with a suggestion that this may not accurately reflect the properties of the numbers themselves.
  • Several participants challenge the notion that sqrt(2) exists, arguing that its infinite decimal representation leads to a lack of well-definedness.
  • There is a discussion about whether the properties of rational numbers should be used to define well-definedness for irrational numbers.
Participants do not reach a consensus on the existence of irrational numbers or the criteria for well-definedness. Multiple competing views remain, with some arguing for the existence of irrational numbers and others questioning their validity based on definitions and representations.
Limitations in the discussion include varying definitions of existence and well-definedness, as well as differing interpretations of mathematical constructs. The debate reflects unresolved philosophical and mathematical questions regarding the nature of numbers.
  • #61
Yes. Is it not a surreal fantasy about infinitely thin knives that produces a useable definition for infinitely 'thin' numbers? Whether such numbers exist (or whether numbers can be coherently defined in this way), I was suggesting, can be determined from examining the definition.
I suppose my thought is that there is no way to define a continuous series of numbers such that the numbers are determinate. Or something like that. Counting apples is easy enough, but dividing a continuum into finite parts requires a leap of imagination that leaves reality behind.
  • #62
My theory is that people who disagree about these things are the ones who would answer the question "does god know all decimals of pi?" differently.
  • #63
Differently to what? Damn silly question is the answer most people would give.
  • #64
Different from each other, of course.
  • #65
Oh yes. I see. Thanks. In that case it's a good point. But I wouldn't agree.
  • #66
Ah here it is! I lost track of this thread.
PeterJ said:
Forgetting the OP then, I'd like to ask something about this.
I see that a region may be well-defined, so that being a region would not necessarily entail that a number is ill-defined. (Is this what you meant?)
Right.
But... couldn't we say it is ill-defined when we forget that it's is a region and treat it like a point, as people often do?
People don't often work with number systems whose numbers are regions. If you are using a number system incorrectly, then you are simply using it correctly.
And, if the end points of a region cannot be well-defined, (because they are points), then couldn't we say that the region is ill-defined?
I'm not sure what sort of geometry you're envisioning where regions have endpoints but points are ill-defined. I suspect you have forgotten that points are points!
If I put a number on the number line then I have to let it cover more than one point
No! The line you drew on a sheet of paper, and the point you marked on it, is not a number line and it is not a geometric point. If you are using such a physical object to help you visualize the mathematical ideas, then you need to understand what parts of the object really do correspond to the math and what parts are simply errors of approximation.
Conversely, if it is the physical object we are trying to study, then the mark on the paper is not a geometric point. For many purposes it is useful to use a geometric point as an approximation, but you would be similarly in error if you think the two are the same.
  • #67
Incidentally, there's a subject jokingly called "pointless topology" where one defines things called locales without reference to the notion of point -- they are just made out of "regions", and you can take finite intersections and arbitrary unions of regions.
But even locales (usually) do have points, and many (most? all?) can be completely and perfectly described as a topological space -- the usual notion of a set of points together with a set of regions that define a topology.
  • #68
Hurkyl - I think I can accept what you say (and I do) without it altering my general point, which comes exactly from trying to understand what parts of the object really do correspond to the math and what parts are simply errors of approximation. For most objects there may be no problem being precise since when we define the object we define it as being one object. An abacus raises no problems of precision. But an infinitely divisible or continuous number line is a unique and idealised object. Or so it seems to me at the moment. Danzig proposes that foundational (and thus metaphysical) issues arise from trying to match the staccato of the numbers to the legato of the number line (or of the world itself), and it's this issue that I find interesting.
I see your point about the dangers of using a physical object to visualise the maths, but I was only using a physical object as a metaphor for the number line. Not so sure I see the importance in this context of the difference between a geometric and a mathematical point. Are they not both man-made objects?
Pointless topology sounds like my kind of thing! That we can describe a locale as a set of points and set of regions may be irrelevant to my concerns, however, since a definition need not be coherent outside of the theory it's designed to support. I was suggesting (if we use the everyday meaning of these words) that a point is a region is a locale, depending on where we are standing, such that that the universe is a point if we stand in the right place. There would be no points on the number line, only arbitrarily defined regions seen from a distance. Or, looking at it the other way, no regions only ill-defined points under magnification.
If this sort of woolly talk is innapropriate here just let me know. I learn in this way, and it's not that I've got some half-baked uber theory of numbers that I'm peddling.
  • #69
Locale theory doesn't equate point with region -- it just takes region as the fundamental primitive all by itself, and tries to describe the relationships between regions without reference to the notion of point.
The contrast with topology is that it takes both "point" and "region" as primitives. (but by invoking set theory, we can identify regions with sets of points)
The net trick is that, using only the notion of "region", we can still develop the notion of a point. One way of looking at it (I believe) boils down to identifying points by specifying a sequence of regions whose "limit" would define the point.
For example, in the locale version of the number line, we can identify the point 3 via the infinite sequence of intervals
(2,4), (2.9,3.1), (2.99,3.11), (2.999,3.111), ...​
(I'm using the normal naming scheme for the open intervals of the number line, because we are all familiar with that naming scheme)
Then, all properties of the point "3" are simply certain kinds of properties of the above sequence of regions. This, of course, is very similar to the classical notion of limits and completeness.
As for "woolly talk", if you're just lightly throwing out any idea that comes to mind, it is inappropriate here. However, if you're serious about trying to pin down actual meanings to the things you say and see how they might be arranged into coherent ideas and how they might relate to things that people have already developed, it might be appropriate in one of the forums here depending on the direction you're going.
Over the years, I have become rather convinced that most people who have some idea of "ill-defined regions" are really struggling to develop the various concepts of topology on their own -- but they have crippled themselves by developing a serious allergy to the notion of a point, so they never even have a chance to learn whether or not their is already a mathematical approach to working with their ideas.
  • #70
Thanks. (I was careful to add 'in the everyday sense' when I used these words.)
That's how I imagine points are usually defined, as the end point of a never ending process. I assume that they simply have to be defined in this sort of way. It's the issues this raises that interest me.
Very excellent comment. I'd never thought of this. Must be annoying. But there can be some reasoning behind a dislike of points, as you'll be well aware, and it's not necessarily just an allergy. I see no possibility of constructing a coherent metaphysic for which points are not a convenient fiction, and I think this is a quite widespread view. This raises some important mathematical issues, and it makes the relationship between mathematics and reality an important issue for everybody, not just mathematicians.
Now you come to mention it I realize that it's true, I've never enquired whether there's a mathematical approach that would encompass my ideas about the numbers. I expect the answer would take me well out of my depths, and anyway, it seems to me all the maths is already done. Peirce's arithmetic of circles and Spencer-Brown's calculus of indications would get my vote as a place to start, as they're conceptually simple and I share their view of points/numbers'regions etc as far as I can tell, but I don't know whether they'd be relevant here. I don't think they'd have any bearing on the definition of points, for example, for this would be a matter of convenience.
Is it safe to say that a continuum, whether it is the number line or spacetime, and regardless of whether it is conceptual or real, cannot be made of points according to reason. Or is even this debatable?
  • #71
Hurkyl? Anybody? I'm getting a little bit paranoid at the lack of response. Was that not an appropriate question here? I suppose it's not exactly a mathematical question. Or is it? It wasn't a trap anyway. I was trying to understand how mathematicians see these issues, exactly where they feel that mathematics turns into metaphysics and so draw the line. Personal opinion would be be fine.
Or is it that mathematicians have no time for such idiotic questions? I think the answer to it is clearly yes, but I don't know if this is a commonplace opinion in mathematics or utter heresy, or even of any interest, and I have no idea as to what the mathematical implications of either answer would be. Brown and Peirce would have answered the same way, if I understand them correctly, but don't imagine I can follow even Brown's painfully simple calculus once it becomes a system of symbols.
Perhaps everyone's down the pub.
  • #72
Generally, "point" is never defined at all.
A typical version of the theory of Euclidean geometry, for example, takes "point" as one of its "primitive notions" (others tend to include "line", "lies on", "between" and "congruent") and never attempts to define it. Instead, it postulates the properties that points have, and studies the consequences of those properties.
A typical version of the theory of real numbers is similar. It takes "number" as a primitive notion along with 0, 1, +, *, and <, and postulates the complete ordered field axioms.
A definition of "point" only comes when you want to apply Euclidean geometry to some purpose. e.g. a physical theory might assert that there is a notion of "position" in the universe, which obeys all of the axioms of Euclidean geometry describing points.
Another example is that, to better study the arithmetic of real numbers, we might define a model of Euclidean geometry in which "point" is interpreted to mean an ordered pair of real numbers. Conversely, in order to better study Euclidean geometry, we might construct a number line -- a model of the theory of real numbers -- and work with coordinates. In this sense, the two theories are actually the same theory just presented differently.
Locale theory defines "point", but that's simply because, pedagogically, it doesn't seem useful to take it as a primitive notion. I'm sure that would change if it was shown to be useful.
As you might guess I'm a formalist. But only weakly -- I don't make any assertions on whether or not mathematics has meaning, I just assert that the meaning isn't part to the formalism.
_______________________________________________________________
Now, I tend to get a little uneasy when people talk about "never-ending processes". It's a perfectly good idea, but there are a lot of misconceptions often associated with it.
The most common, I think, is of this form. When talking about things in this way, it is the process itself that names the point. (maybe we have defined "point" to literally be the process, or maybe as a limit in some suitable sense, or some other way to associate the name to the point) However, sometimes people get in their heads that the point is supposed to be the result of the process, either taken after some ill-defined number of steps, or after some mythical final step.
I can't actually tell if you have a bad idea in your head, I'm just a little uneasy about it.
It's a typical approach to naming things. You identify objects by some property they have -- in this case, a point is identified by a collection of "regions" that would contain it, but you need infinitely many regions to uniquely pin down the point.
The definition I cited is actually the unrolling of a simpler definition -- there is a locale called "*", and a "point of the locale L" is really just a mapping from * to L. But when you unfold all the complexities of the locale of real numbers, the locale-theoretic meaning of "point" transforms into something similar to and equivalent to the one I stated.
Typically, definitions that apply in most or all cases of interest tend to require infinite amounts of information. Specific cases often require much less -- e.g. for the Euclidean line, I could instead fix an orientation and name points with intervals (with the idea that the point is to be the left endpoint of the interval). But this particular scheme is very specific to the Euclidean line.
The real numbers suffer from this too. General naming schemes (like decimals, or continued fractions) tend to require infinite amounts of data. However, specific numbers can often be named with much simpler methods, such as the positive square root of 2.
True or not, convenient fictions are, well, convenient. That's why we have them. :smile: It's analogous to scaffolding -- in the end, all you care about is building a building, but it's much easier to do so if you build the scaffolding along with the building, then remove the scaffolding at the end.
This is ubiquitous in mathematics. e.g. if we decide to name rational numbers with names of the form x/y where x and y are integers, one of the first things we do is decide which names really do name rational numbers (1/0 does not), and decide when two different names name the same object (e.g. 2/3 and 4/6). This extends to mathematical structures, structures of structures, and so forth.
This is also one of the reasons physicists are so interested in symmetries. e.g. from the fact the laws of classical mechanics are symmetric under rotations and translations of Euclidean space, we deduce things like an absolute notion of "position" or "direction" have no physical meaning.
  • #73
H - Many thanks for a really helpful post! Maybe what I'm exploring is to do with the boundary between mathematical formalism and realism. I'm now a little more clear about one or two things and I'll shut up about this now.
Btw - re the primes - I'll stop bothering you about this also. I've managed to track down a retired prof who is prepared to do a bit of tutoring so I'll see how that goes.
You've been very helpful and patient - thanks.
  • #74
I think Hurkyl is pointing out the main difference between those who tend to be skeptical towards irrational numbers and those who are not.
Hurkyl, what is your opinion about treating the real numbers as a primitive notion; rather than constructing them from the naturals? I know this is an essentialist issue, but even as a formalist, the essentialist aspect need not be ignored.
  • · Replies 30 ·
  • · Replies 19 ·
9K
