Irrationality of Difference of two numbers
  • Thread starter Thread starter smiles988
    Difference Numbers
The expression \(\sqrt{8} - \sqrt{3}\) is proven to be irrational by employing a proof by contradiction. Assuming \(\sqrt{8} - \sqrt{3}\) is rational leads to a contradiction when manipulating the equation with the known irrationality of \(\sqrt{3}\). The discussion also touches on the general principle that \(\sqrt{x}\) is rational if and only if \(x\) is a perfect square, reinforcing the irrationality of non-perfect square roots.
  • Understanding of irrational numbers and their properties
  • Familiarity with proof by contradiction techniques
  • Basic knowledge of algebraic manipulation involving square roots
  • Concept of rational numbers in the form \(\frac{p}{q}\)
  • Study the properties of irrational numbers in number theory
  • Learn advanced proof techniques in mathematics, particularly proof by contradiction
  • Explore the implications of perfect squares on rationality of square roots
  • Investigate other examples of irrational number proofs, such as \(\sqrt{2}\) and \(\sqrt{5}\)
Mathematics students, educators, and anyone interested in number theory and the properties of irrational numbers.
smiles988
Proof of Irrationality
How can I prove that the square root of 8 minus the square root of 3 is an irrational number using the fact that the square root of 3 is an irrational number? I know I need to use a proof by contradiction, but I am stuck after that.
\sqrt{8}-\sqrt{3} is an irrational number.
Use the fact that \sqrt{3} is an irrational number to prove the following theorem.
A rational number can be written in the form \frac{p}{q} where p and q are integers in lowest terms.
I know that I need to use a proof by contradiction to solve this problem. Therefore, we would assume that \sqrt{8}-\sqrt{3} is an rational number and that \sqrt{3} is an irrational number and try and reason to a contradiction. I am stuck and don't know how to get to the contradiction.
well it's actually asking to prove that
(sqrt(2)+sqrt(3))+sqrt(2)
is irrational.
assume it equals p/q where (p,q)=1
then multiply by sqrt(8)-sqrt(3)
youll get that sqrt(8)-sqrt(3)=5q/p
and you also have sqrt(8)+sqrt(3)=p/q
so you get that 4sqrt(2)=5q/p+p/q
which yields: sqrt(2)=(5q/p+p/q)/4 which is a contradiction.
you could have easily have done it with sqrt(3) instead but it doesn't matter.
well, i had mistaken sqrt(8)-sqrt(3) with sqrt(8)+sqrt(3) but it doenst matter the same idea will work as well as in this case.
Suppose that it is, then this implies that the square root of 8 is what?
Just to add something to review my number theory.Another idea:
I think a nice general result is that for x a pos. integer, sqr(x) is rational iff x is a perfect square (an integer, of course). Think x=a^2/b^2 , so a^2x=b^2 . Then think of what the factorization of x needs to satisfy in order for a^2x to be a perfect square.
x=p_1^e_1...p_ne^n .
Then , re your problem, think of what happens when you square your expression.
I believe this is the third time you have posted this same question in a separate thread!
  • · Replies 24 ·
  • · Replies 22 ·
  • · Replies 26 ·
20K
10K
