Irreversibility of a Process: Finding ΔQ and ΔS of a Mass Dropped into the Sea
The discussion focuses on calculating the irreversibility of a process involving a mass dropped into the sea, specifically analyzing the changes in heat (ΔQ) and entropy (ΔS). The relevant equations include I = T_0 (ΔS + ΔS_E) and I = W_rev - W, where it is established that no work is involved in this scenario (ΔW = 0). The entropy change for the sea is calculated as ΔS_sea = mc(T_2 - T_1)/T_2, while the entropy change for the mass is derived using dS = dQ/T and integrating to find ΔS_block = mc log(T_0/T_1). The sea's entropy increases as it absorbs heat from the mass.
  • Understanding of thermodynamics concepts, specifically heat transfer and entropy.
  • Familiarity with the first law of thermodynamics.
  • Knowledge of integrating functions in calculus.
  • Experience with logarithmic functions and their applications in thermodynamic equations.
  • Study the first law of thermodynamics in detail, focusing on heat transfer and work.
  • Learn about entropy calculations in thermodynamic processes, including irreversible processes.
  • Explore the concept of heat capacity and its implications in thermal systems.
  • Investigate the mathematical integration of thermodynamic equations, particularly in relation to entropy changes.
Students studying thermodynamics, physicists analyzing heat transfer processes, and engineers involved in energy systems design.
Gregg
A mass m with heat capacity c at temperature T_1 is dropped into the sea at T_2.
What is the irreversibility of the process?
I = T_0 (\Delta S + \Delta S_E )
I = W_{\text{rev}} - W
Heat in is Q=mc\Delta T the temperature of the sea remains constant by the first law W=Q. What is the distinction between the work for a reversible process and the work?
No work is involved. ΔW =0, ΔU = -Q for the mass and +Q for the sea.
U of the sea does change, albeit mightily little.
Write an expression for the entropy change of the mass and of the sea.
What constitutes the irreversibility calls for a verbal answer, plus reference to the line above.
Well since the mass of the sea is not given I assume that the change in internal energy is negligable. Made an error with work! Of course there is no work.
So the key is to find the entropy change of the sea and of the block.
\Delta s_{\text{sea}} = \frac{mc(T_2-T_1)}{T_2}
\Delta s_{\text{block}} = ?
is it log?
No, U of the sea goes up. It's an infinite mass all right, so an infinitely small rise in temperature, but ΔU and Q go up together & are finite. Where do you think the loss of Q from the mass goes? Of course, ΔT of the sea is essentially zero. Have to be careful with infinities and zeros.
is it log?
Yes. You have dS = dQ/T and dQ=mc dT. Put those together and integrate.
I = T_0(mc(\frac{T_0-T_1}{T_0})+mc \log(\frac{T_0}{T_1}))
T_1 > T_0. So, is \Delta S_{\text{sea}} < 0 ?
I know that mc \log (\frac{T_0}{T_1}) < 0
No, the sea absorbs heat, so its entropy increases.
Anyway, you got ΔQ and ΔS for the mass correct now. Although, simplify by writing ΔQ of mass = mc(T2 - T1).
So what do you think ΔQ of the sea is? And then ΔS of the sea?
  • · Replies 60 ·
10K
  • · Replies 22 ·
