Is a Closed-Form Solution Possible for the Integral of e^cos(x)?
  • Thread starter Thread starter Si14
    Dx Integral
The discussion revolves around the integral of e^cos(x), with participants exploring the possibility of finding a closed-form solution without resorting to series expansion or numerical methods.
  • Participants discuss various approaches, including substitution and integration by parts, while expressing doubts about the feasibility of obtaining a closed-form solution. Some question the definitions of elementary functions and the nature of the integral.
The conversation reflects a mix of attempts to manipulate the integral and skepticism about the existence of a closed-form solution. Some participants suggest that the integral may relate to special functions, while others express frustration with the complexity of the problem.
There is a mention of constraints regarding the use of numerical methods and series expansions, as well as references to tools like Wolfram Alpha and Maple 11, which have not provided satisfactory results for the participants' needs.
Si14
I want to solve this integral without using series expansion. The answer should be in a closed form. I wonder if this is possible?
I used numerical methods and was able to solve it numerically for a given interval. However, I need to solve it without using numerical methods and without using series expansion.
Thanks.
Try using substitution: Let y = cos x
sharks, it seems that it gets more complicated!
I stuck immediately after substitution.
Thanks.
I suspect it is not doable in terms of elementary functions. Neither Wolfram Alpha nor Maple 11 can find non-series expressions for the indefinite integral. You might try converting it so some known special (but non-elementary) function, perhaps by using integration by parts and/or substitution methods.
RGV
[tex]\int e^y.\frac{-1}{\sqrt{1-y^2}}dy[/tex]Then, use integration by parts.
I wonder if it is possible to solve the indefinite integral? I assume the answer to the definite one should be close to the answer I get with numerical methods.
As I said, the primitive function is not elementary
Wolfram Alpha
I checked wolframalpha. However, it gives a series expansion which I can not use.
I wonder if the integration by parts suggested by sharks is doable?
You obviouly don't know what primitive or elementary means. Did you see the first sentence mentioned in wolfram alpha? It tells an even more stringent condition, in terms of "standard mathematical functions", which includes some non-elementary functions (including Bessel functions).
Try ##u=e^y## and ##dv=\frac{-1}{\sqrt{1-y^2}}##
Then, ##du=e^y## and ##v=\cos^{-1}y##
It won't get you anywhere; the integral is non-elementary, and no amount of manipulation will change that fact. However, you might try to re-express the indefinite integral in terms of some already-defined special functions (as already suggested).
RGV
  • · Replies 16 ·
