Is an Oil Distribution System Necessary for Optimal Oil Immersion Microscopy?
  • Context: Graduate
  • Thread starter Thread starter cohkka
    Microscope Oil
The discussion revolves around the necessity of an oil distribution system for optimal oil immersion microscopy, particularly in scenarios where the lens and specimen may move relative to each other. Participants explore the implications of oil thickness, heating effects from light, and the mechanics of maintaining alignment during imaging of non-living nanoparticles and gel layers.
  • One participant notes that oil is required to increase the numerical aperture and resolution of the lens in oil immersion microscopy.
  • Concerns are raised about the need for a constant thickness of oil if the lens and specimen are moving relative to each other.
  • Another participant suggests that an oil dispensing mechanism may be necessary if the coverslip is moving relative to the lens.
  • It is mentioned that intense light can heat the oil and sample, with some sources being IR filtered to minimize this effect.
  • A participant questions how to maintain mechanical alignment between the objective and the moving sample, particularly when the specimen is a stationary gel layer.
  • Clarification is provided that moving the sample in the x-y plane can affect the distance between the lens and the sample due to potential misalignment.
Participants express uncertainty about the necessity of an oil distribution system, with some proposing it may be needed while others discuss mechanical alignment issues. The discussion remains unresolved regarding the optimal approach for oil immersion microscopy in the described scenarios.
Participants mention that immersion lenses typically require a coverslip and that 'dipping' lenses differ in design. There are also considerations about the thermal effects on the oil and sample, as well as the potential need for correction collars in immersion lenses.
cohkka
For oil immersion microscopy, I understand that the oil is required to increase the numerical aperture, and thus the resolution, of the lens. I have tried looking into these microscopes and the only method I have seen of applying the oil is to place a dot of it on the lens and then lower the lens into the specimen. However, what if the lens and specimen are moving relative to each other? Wouldn't you need an oil layer of constant thickness? Also, when imaging very thin layers, wouldn't the oil be heated significantly by the light from the microscope?
Basically, my question is whether one would need to install an oil distribution system to prevent overheating of the oil and to ensure that an even layer is coating the lens. Do you know if this has been researched? I cannot find information on it anywhere!
I figure that the oil would have to be introduced in a laminar flow onto the coverslip but I'm just unsure if this is actually necessary. I would be dealing with nanoparticles, but none of which are living. Thanks for your help in advance!
Science news on Phys.org
Generally, immersion lenses require use of a coverslip; 'dipping' lenses are different, and are designed to be dipped directly into the (usually) aqueous medium in which the specimen resides.
If your coverslip is moving relative to the lens, then yes- you will need a oil dispensing mechanism. However, given the tight clearances (immersion lenses are often only a few tens of microns above the coverslip surface) and depth of focus (a fraction of a micron), I would wonder how you propose to maintain mechanical alignment between the objective and moving sample.
If you are imaging, for example, a fluid channel through which material flows, there's no issue- the coverslip and channel are stationary and the fluid flow is isolated from the environment via the coverslip.
It is true that the intense light at the focal plane can heat the sample (and everything else); most sources are IR filtered to minimize this effect. For critical applications (say cryogenic microscopy), the sample holder is thermally isolated from everything else (the stage motors will also heat the sample). Some immersion lenses have a correction collar to account for the thermally induced changes to the oil refractive index.
Thanks for the reply! I'm a little confused though; what do you mean by maintaining mechanical alignment between the objective and moving sample? The specimen would be a layer of gel spun onto a substrate, so there is no flow, with a coverslip on top. Do you mean that in moving the specimen in the x-y plane, the focal point would be affected?
Sorry- yes. Moving the sample in x-y will generally change the distance between the lens and sample due to misalignment of the sample plane (and directions of motion) with the optical axis of the microscope.
Ah okay, thanks! I hadn't thought of that so will have to take that into consideration!
