Is f(x) = 1/log|x| Continuous at x=0?
  • Level: Undergrad
  • Thread starter zorro
    Continuity
10 replies · 7K views · last reply
zorro
Is the function f(x) = 1/log|x| discontinuous at x=0? My book says yes. It is continuous according to me. Can somebody verify?
Note that all you have to show is that given some [itex]\epsilon>0[/itex], you can always find a [itex]\delta>0[/itex], so that for any x fulfilling [itex]0<x<\delta[/itex], we have:
[tex]\frac{1}{|\log|x||}<\epsilon[/tex]
The function f is not defined for x=0 and this is a condition, so it is not continuous in 0.
Note however, that if you expand the definition of f, so that f(0)=0, then it is continuous in 0.
My bad.
Of course it is discontinuous at x=0, since it isn't defined there.
I Like Serena has pointed out how to make a continuous extension of f, a feat that is possible since the limit of f at x=0 exists.
For another example, the function
[tex]f(x)= \frac{x^2- 1}{x- 1}[/tex]
is NOT continuous at x= 0 even though for all x except 0 it is equal to x+ 1 which is.
No it does not.
It shows a function where the two-sided limit at x=0 exists.
That is not sufficient to establish continuity.
Any numerical grapher can show only an "approximate" graph since it can calculate values only for a finite number of points.
The function f(x) = 1/log|x| for all x non-zero, 0 for x=0 is continuous.
I assume you mean x=1 for that function. It's well-defined at x=0, it's f(0)=1.
