Is frictionless vacuum possible?
  • Context: Graduate
  • Thread starter Thread starter blahsd
    Frictionless Vacuum
The discussion revolves around the concept of a frictionless vacuum and its implications for creating a perpetual motion machine or apparatus. Participants explore the feasibility of suspending a piece of metal between magnets in a vacuum-sealed environment, considering both theoretical and practical aspects of motion and energy loss.
  • Some participants propose that a piece of metal in motion within a perfect vacuum could be seen as perpetual motion, though it is clarified that this does not constitute a machine.
  • Others argue that the concept of a perpetual motion apparatus is problematic due to the law of conservation of energy, and they express caution in terminology.
  • A participant suggests that eddy currents may dampen the motion of the metal, potentially leading to energy loss.
  • There is a discussion about the possibility of a spacecraft in space being in perpetual motion, although it is noted that it cannot be used to perform work without slowing down.
  • Some participants question the practicality of stabilizing a piece of metal suspended in air using only permanent magnets, with references to superconducting flywheels as a potential solution.
  • Concerns are raised about the challenges of maintaining the metal's position while evacuating air from the jar, with differing opinions on the feasibility of this process.
  • Participants mention that spinning objects can be stabilized, referencing toys that demonstrate this principle.
Participants express a range of views on the feasibility of creating a frictionless vacuum and the potential for perpetual motion. There is no consensus on the practicality of the proposed apparatus, and multiple competing ideas remain unresolved.
Limitations include the assumptions about the nature of the vacuum, the effects of eddy currents, and the practical challenges of maintaining motion in a sealed environment. The discussion does not resolve these complexities.
blahsd
Would a piece of metal suspended between two magnets in a vacuum-sealed jar be in a situation of frictionless vacuum? If yes, could such a situation be exploited to build a perpetual motion machine? If no, would the friction be enough to result in an appreciable loss of energy if the piece of metal was to be set in motion?
Let's be clear. A piece of metal set in motion in a perfect vacuum could be considered to be in perpetual motion, however it is not a machine. A machine is something used to accomplish a task, something you get work out of. A perpetual motion machine is not possible and is against PF rules for discussion, so just be careful.
Sorry! Bad terminology usage. I didn't mean any offense to the law of conservation of energy. Could you call that a perpetual motion apparatus? Is that possible to realize?
I am unsure if your specific example would work, however it seems plausible to me.
"...metal suspended between two magnets...in motion..."
WAG here, but eddy currents might come into play and eventually damp the system.
A spacecraft in the vacuum of space could also be considered in perpetual motion (even though even the vacuum of space is not perfect). No need to invoke magnets, it'll keep going almost forever. However, once you try to get some work out of it you WILL slow it down, one way or another.
It all depends on how picky you are. The Earth has been orbiting the sun for some 4 or 5 billion years and will orbit for several billion more. It won't orbit forever, nor will your magnetically levitated object spin forever. So you'll have to decide if that's close enough for you.
Drakkith: thanks then.
Greg23: I'm not trying to get work out of it. Sorry if my wording was wrong.
Lsos: except I can't use a spacecraft as a ornament for my desk (the intended use for my apparatus)
russ_watters: if I could put it on my desk and die of old age before it stops spinning I would be much more than satisfied. So I guess it could work!
There one question left though. How can you set in motion something sealed in a jar?
Start it spinning before you close the jar and pump out the air
I understand now what you're trying to do. Someone correct me if I'm wrong, but isn't it impossible to keep a piece of metal stabilized suspended in air with only permanent magnets?
"Greg23: I'm not trying to get work out of it. Sorry if my wording was wrong."
You wording seems fine.
But, again a WAG, it seems that any metal object moving in a magnetic field will have eddy currents generated inside the metal. There is a YouTube video showing a magnet falling in a copper tube that is slowed by eddy currents. In your case the magnetic field is fixed and the metal is moving. Same result. Small, but potentially fatal.
True. This is one reason for why superconducting flywheels are quite attractive (superconductors are diamagnetic, so they CAN be used to create stable configurations). This is essentially what the OP was describing. A flywheel can essentially be used as a battery, and has -in certain circumstances- several advantages over a chemical battery for energy storage.
However, no flywheel is perfect, and eventually it will come to a stop.
I'm almost sure you can keep a piece of metal suspended for a short while if its spinning... There was some kind of toy doing it.
Yes, a spinning top can be made stable (with some difficulty). But the nice thing about superconductors is that you don't need anything to hold the wheel BEFORE it starts spinning.
Hardest part may be to keep the metal in the magnetic field while you pump out the air. It will certainly try to escape through your opening, affecting your ability to continue pumping and to continue rotation.
Unlikely. Most vacuum pumps don't suck air out very quickly. And since your don't have a FLOW of air through the chamber, unless the object is extremely close to the opening, there won't be any wind.
  • · Replies 37 ·
27K
  • · Replies 21 ·
  • · Replies 62 ·
12K
