Is G a Connected Group? Proving Connectivity in a Matrix Set
  • Thread starter Thread starter Spriteling
    Set
The discussion revolves around proving the connectivity of a group G defined by a specific matrix form involving parameters u, v, and θ. Participants explore the properties of connectedness in the context of group theory and matrix representations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants consider various methods to demonstrate that G is not the disjoint union of two non-empty sets. There is discussion about using path connectivity and parametrization by real numbers. One participant proposes a function to connect two elements in G, while another questions the validity of this approach by providing a counterexample.
The conversation is ongoing, with participants actively questioning assumptions and exploring different approaches to establish connectivity. Some guidance has been offered regarding the need for careful consideration of the matrix form, but no consensus has been reached on a definitive method.
Participants are grappling with the challenge of finding a suitable curve that satisfies the conditions for connectivity, while also considering the implications of expressing elements of G in terms of exponential forms.
Spriteling
Show that the group G where [itex]G = \left(\begin{array}{ccc} \cos\theta & -<br /> sin\theta & u \\ \sin\theta & \cos\theta & v \\ 0 & 0 & 1 \end{array} \right) u,v \in \Re, \theta \in \Re/2\pi Z[/itex]
I know that a set is connected if it is not the disjoint union of two non-empty sets, if any two elements in G can be joined by a [itex]C^k[/itex] path in G, and if G is generated by a neighbourhood of 1.
I thought that it would be easiest to show that G is not the disjoint union of two non-empty sets, and I was trying to do it by contradiction, but got nowhere.
Any hints/nudges in the right direction would be appreciated.
Path connectivity is often the easiest direction to go in, especially when your set is parametrized by real numbers
Would it then work to say that you can take the function f: [0,1] -> G, where f = tg + (1-t)g' with g, g' members of G. f(0) =g and f(1) = g' so G is indeed connected?
Or am I missing something here?
That's not quite right. Imagine
[tex]g = \left(\begin{array}{ccc} 1 & <br /> 0 & 0\\ 0 & 1 & 0 \\ 0 & 0 & 1 \end{array} \right)[/tex]
[tex]g' = \left(\begin{array}{ccc} 0 & <br /> -1 & 0\\ 1 & 0 & 0 \\ 0 & 0 & 1 \end{array} \right)[/tex]
then the halfway point is
[tex]g = \left(\begin{array}{ccc} 1/2 & -<br /> 1/2 & 0\\ 1/2 & 1/2 & 0 \\ 0 & 0 & 1 \end{array} \right)[/tex]
which isn't actually of the desired form. You need to be a little more careful about how you deal with the sin and cos terms
Any hints/nudges in the right direction would be appreciated.[/QUOTE]
Yeah, I realized that last night when I was showering.
However, I can't seem to find a curve that will actually suit all of the conditions, namely that:
f(t) = a(t)g + b(t)g' with b(t) + a(t) = 1 from the bottom right corner and that a(t)cos(x) + b(t)cos(y) = cos(z) and a(t)sin(x) + b(t)sin(y) = sin(z).
I think it may just be easier to show that any g in G can be written as an exponential, and so then all points are joined together.
  • · Replies 26 ·
