Is Higher Clock Speed or More Cores Better for a CPU?
  • Context: Calculators
  • Thread starter Thread starter MechSoup
    Clock Speed
The discussion revolves around the comparative advantages and disadvantages of higher clock speeds versus more CPU cores. Participants explore the implications of these factors on performance, efficiency, and software compatibility, touching on theoretical and practical aspects of CPU design and usage.
  • Some participants define multi-core processors as having multiple cores that can handle tasks simultaneously, while clock speed refers to the rate at which a single core processes information.
  • There is a suggestion that a high multi-core unit with lower clock speed could theoretically match the performance of a single core with high clock speed, raising questions about the shift towards multi-core designs.
  • One participant mentions reaching a limit on CPU clock speeds due to heat generation, suggesting that higher speeds require more advanced cooling solutions.
  • Another participant discusses how modern CPUs utilize hyperthreading, allowing each core to handle multiple threads, which may enhance performance without needing to increase clock speed significantly.
  • Concerns are raised about the limitations of multi-core advantages, particularly in cases where tasks cannot be easily parallelized, leading to a discussion on the necessity of software optimization for multi-core utilization.
  • Some participants argue that while multi-core processors may be more efficient in terms of heat generation and power consumption, the practical benefits depend on the software's ability to leverage multiple cores effectively.
  • Questions arise regarding the interpretation of clock speed in multi-core processors, specifically whether the stated speed applies to each core individually or collectively.
Participants express a range of views on the efficiency and practicality of multi-core versus high clock speed CPUs. There is no clear consensus, as some argue for the advantages of multi-core designs while others highlight the challenges and limitations associated with them.
Participants acknowledge that not all software can effectively utilize multiple cores, which may limit the performance gains from multi-core processors. Additionally, there are unresolved questions regarding the thermodynamic implications of CPU performance and the specifics of clock speed in multi-core configurations.
MechSoup
I'm not sure I understand the advantages or disadvantages of each.
I imagine Multi-core (in the dual case) as two processors working on the same information to complete the task (reading, writing, whatever) in half the time.
I imagine Clock Speed (I'm not sure if this is what you call it: ie: 3.4Ghz processor) as the rate at which it processes the information.
If the above definitions are correct, then couldn't a high multi-core unit (with low clock speed) complete the same information in the same amount of time as a single core (with high clock speed)? Yet the single core is much cheaper?
If this is the case, when why is everything going multi core and not increased clock speed?
I have read Wikipedia and different articles, but I just need a down to Earth definition.
Thanks!
Computer science news on Phys.org
Thanks!
I believe that they have reached a limit on the speed of the cpus. I am into overclocking myself, which means that I manually bring the speed of the cpu higher then its rated clock speed. I have noticed that some chips are purposely underclocked. This means that they are just rebranded higher end chips generally speaking from what I have heard. However as the clock speeds get higher the heat gets higher. With the more heat a more expensive cooler will be needed and that means the price of the computer will go up. However, there is still a cap on how fast it can go without needing extreme forms of cooling.
In multi core like the intel core 2 series, each core could process a 1 and a 0. So it would take two separate cores to process a 1 and a 0. However with the new series of Core I7s and other cpus before the core 2 supports hyperthreading. This means that each core, or cpu if you will, will be able to process a 0 and a 1 using the same core rather then the old architecture that needed two separate cores.
We are moving to multi core cpus because they can handle more information at a given time and especially with the same speed. So that means more information done faster. The single core could technically keep up, but the speed to do so would have to be very high.
I hope this answers your question, and anyone correct me if I am wrong.
The multi-core advantage is not n*x as some calculations are linear, with the next calculation based on the results of the last. Such operations can't easily be split to run in parallel.
Right, this is why programs are specially coded for multi core cpus. Right?
As you increase a CPUs core speed, you generate a lot of heat. At some point it becomes impractical to continue pushing the envelope. With smaller architectures, it became possible to embed two or four or eight cores onto a single chip. Creating a 4GHz processor for personal computers is a much less convenient task for chip designers than putting two 2GHz processors on one chip. Now you have 8-core CPUs that, even at 2GHz, would be impossible for CPU makers to match and turn into a commercial product (16GHz?).
The catch with multi-core processors is the fact that not all software can use them. Back in the day when they were first coming out they were practically useless. Very few programs were able to use parallel processing and one core would go completely untouched. I can't say for sure, but I would bet it's not a trivial task to redesign software to use parallel processing.
It's not easy to rewrite software to be parallel by itself, so not many individual applications get much of a speed increase with mutlicore -- BUT it is pretty easy to split the work of multiple independent programs across cores.
Basically, your spreadsheet doesn't go 8x faster, but it doesn't slow down because you are also chatting on skype, playing an MP3, filtering e-mail, browsing the internet, etc at the same time.
It would make sense then, that multi core processors are also more efficient then high clock speed single core processors as a single core will generate more heat to do the same amount of work?
Overclocking a multi core would destroy the efficiency gains. Alas! Performance will always prevail! Thank you gentlemen for your input.
Wait, what? Are you talking about efficiency in the thermodynamic aspect? The problem is not with them being too hot to be efficient (in the thermodynamic or data manipulation sense), it's that you can only have a processor become so hot before the cooling requirements become too much for desktop computers.
Sure. It would make sense that a processor that could perform that same work in the same amount of time with less heat is more efficient in its power consumption?
I would assume that you are referring to the limiting factor? As in why we do not create higher frequency CPUs? I suppose that you could look at it on a thermodynamic perspective.
Also, if a Multi Core processor says that it has a clock speed of 2.8Ghz, does that mean that each core operates at this speed? Or is it that the combined output is equal to that speed? Maybe I am looking at it wrong. . . if it is an operating frequency, then they must be that same? Right? I guess I was thinking that each processor (in the dual case) would be 2.8Ghz/2. . .
Chip designers are really not at all worried about a CPUs power consumption unless you're dealing with laptop CPU. With laptop CPUs, you sometimes don't want to have a higher clock speed. To be honest, none of that is really important to laptops either. CPUs are rarely going at 100% and if you're on a laptop, you're very very rarely hitting 100% on the CPU.
No, you can't. A CPU processing data is not a thermodynamic process. There is heat generated and there are parts of the whole system you can view thermodynamically, but that does not mean the CPU process is subject to the same kind of analysis you'd do on a car engine.
No, when manufacturers say they have a 3.0ghz quad core CPU, that means there are 4 cores running at 3ghz each.
I can see what you mean, and your logic is sound. I even found an article proving your point. I guess what I was thinking was that the power required to run a multi core was the same as a single core, which is not true.
Thank you for the clarification. ;)
14K
  • · Replies 59 ·
  • · Replies 26 ·
34K
20K
  • · Replies 20 ·
