Is hydrogen energy truly sustainable or just a deceptive hoax?
  • Context: Undergrad
  • Thread starter Thread starter Ar edhel
    Energy Hydrogen
The discussion centers on the sustainability and viability of hydrogen as an energy source, exploring its role as an energy carrier versus a source, the efficiency of hydrogen production and use, and the implications of current policies regarding hydrogen energy. Participants engage in technical reasoning, conceptual clarifications, and debates about the hydrogen economy.
  • Some participants argue that hydrogen cannot be a sustainable energy source in a closed system, as energy is lost in the conversion process from water to hydrogen and back.
  • Others clarify that hydrogen is primarily an energy carrier, not a source, and compare it to electric power lines in terms of energy transportation.
  • There is a discussion about the efficiency of various engines, with some participants suggesting that fuel cells may be more efficient than internal combustion engines.
  • One participant raises questions about the energy conversion losses when converting petroleum to hydrogen, indicating uncertainty about the efficiency of this process.
  • Some participants express concern that misconceptions about hydrogen energy may be perpetuated by misinformation or a lack of understanding.
  • A later reply mentions the rapid advancements in hydrogen technology, suggesting that future efficiencies may differ from current estimates.
  • There is a critique of current policies prioritizing hydrogen over other energy solutions, with references to political influences on energy policy.
Participants generally disagree on the sustainability and efficiency of hydrogen as an energy solution, with multiple competing views on its role and effectiveness in the energy landscape. The discussion remains unresolved regarding the overall viability of hydrogen energy.
Limitations include varying assumptions about engine efficiencies, the efficiency of hydrogen production methods, and the influence of political factors on energy policy. Participants express differing views on the implications of these factors.
This discussion may be of interest to individuals exploring alternative energy solutions, policymakers, and those studying energy efficiency and sustainability in the context of hydrogen energy.
Ar edhel
ok I am not bright, but hydrogen can only work if an outside energy system supplies more energy then is actually harnessed by its combustion.
in a simple closed system, if water is converted into hydrogen then back into water. it is a scientific fact the system could only loose energy. even using every ounce of hydrogen energy created, that energy would never be enough to even sustain the loop... let alone power millions and millions of cars. if you wished to extract the equivalent of 1 single battery, more then 1 battery's worth of energy would need to be expended in order to create the hydrogen equivalent. the only reason hydrogen is considered at all is because, once you have hydrogen sensless masses think wow this is great no harmful by products. and others even simpler believe they can just keep converting it back and forth as though man was able to create a perfect pendulum.
It holds many possibilities though, if it can be harnessed through natural sources like swamps. or using massively efficient factories that can convert energy from other, less user friendly sources. it is quite possible that hydrogen could be a very effective form of holding and transporting raw energy... however to create hydrogen, would the companies and government let us into the secret that they had to use up, a greater equivalent of another form of energy?
i know my grammar and spelling is weak please post any problems...
Hydrogen is not an energy source, it is a carrier of energy analogous to the electric power lines that criss cross the world. Hydrogen, as viewed by the "hydrogen economy" of the future, is merely a way of transporting energy from one place to another. So you're correct, it is NOT an energy source.
One issue which DOES come up as an aside from it being a transporter of energy, is the fact that if you take petroleum and convert it to gasoline for burning in an internal combustion engine, the amount of usable energy obtained is/potentially is less than that obtained from converting the petroleum to hydrogen and then using that hydrogen in a fuel cell. This is because the fuel cell is relativly efficient (~50%) compared to a car engine which can be less than half that efficient.
Actually, many engines are around 10-15% efficient, well less than half that.
while refining petroleum into gas involves burning of impurities. i would believe adding a complete energy conversion to result in atleast a form of additional loss.
a quick question, if current engines use energy at 15% efficiency. what likely energy conversion loss should we expect? (from petroleum into hydrogen)
Hydrogen can be used in so many ways that it's impossible to give a definitive answer to that. If you're thinking of fuel cells for an electric vehicle, the technology is advancing too rapidly to make a definite statement about what the 'state of the art' will be by the time they become commonplace. The motor and control devices will account for a lot of the efficiency, and they're getting better all of the time too.
Hydrogen, however, can also be burned in a normal (modified) engine the same way that propane and natural gas are now, but the efficiency would be higher simply because 100% of hydrogen is flammable instead of it carrying 'junk' with it into the cylinders. (Some kind of piston-ring lubricant might be needed, but that could be introduced from the oiling system.) It can be used in a turbine engine as well, or a Wankel, or a K-cycle. If you really wanted to, you could even convert it back into water and use it in a steam engine. In any event, other than the steam one, it's going to be better than hydrocarbon fuels in a reciprocating engine.
Let's not get carried away. My car gets 25% efficiency. I just calculated it from my fuel consumption rate.
How would you do that?
What do you drive; a diesel powered auto?
All about Hydrogen as an energy carrier See also the summary of all links to date near the end of the thread.
I think a lot of people are completely uninformed like this guy is about the "hydrogen economy". Most of us realize that yes, it is an energy transportation method but a lot of people think that we are somehow create energy from hydrogen. Are some 'up to no good' people proliferating this idea or what?
No, I think this is a simple misunderstanding caused by a lack of exposure.
I drive a small car (MR2); it needs to put out 20 hp to go 60mph (from car road test results). That's 11,000 ft-lb/s / 88 ft/s = 125 lb or 560 Newtons average force. Gasoline has 30.4 megajoules of energy per liter. Energy divided by force is distance, so expressing energy in liters of gasoline instead of joules, we get 55 km/l. I know that driving at a steady 60 mph, I get better than 14 km/l (that's 33 mpg in US gallons; this I know extremely well, since I have a habit of calculating mpg at EVERY fillup, and know what conditions get me what mpg.) 14/55= 25% efficiency.
I recall one speaker on CSPAN Book-TV talking about global warming. He was very emphatic that what made sense was to get rid of coal, first. The next step was increased production and usage of hybrid vehicles. Hydrogen fueled cars would be a distant third, if it made sense at all.
This is of course in sharp contrast to the current USA administration policy, which puts the "hydrogen economy" first. Anyone who takes even a brief glimpse at the current administration can judge for themselves how much the current adminsitration is driven by concern for the environment, and how much they are driven by political contributions from big businesses such as coal and power companies. A few hints:
The Enron affair, where our current president didn't feel that it was important to hear the conerns of the then California governor, as he was adaquately advised by his staff. Another broad hint comes from the dismisal of the EPA lawsuits against the power companies.
ah think so? I declare conspiracy! Its a ploy by the same people who filmed the faking of the moon landing out in the mojave desert! mmmm desert *homer drool*
I wonder why this stuff doesn't get much coverage though... dare i say science doesn't get a few hours on cnn? lol. Anyone know what the status is on that new power plant permit that the government issued?
Are you crazy? This administration busted Enron and Davis was a f'n criminal! He OPENLY took a bribe from... ah crap anyone know that company... it wasnt publicized much. He cooked the books and forced our state into this "rotating power outage" bull. I wouldn't have listened to that crook if my life depended on it. He was such a crook that we actually voted an austrian actor from hollywood to take his place :confused: :confused: :confused:
And the guy must be obtuse or something. Hybrid still uses gasoline and hydrogen, if created with the sources the administration wants, would be one of the cleanest means of energy use available.
I have first-hand experience with the fact that some people with no scientific knowledge whatsoever, particularly those who are somewhat less than bright, think of fusion (especially bombs) when they hear the word 'hydrogen'. A lot of them don't even know that it burns. Those same people are scared of helium because they think that's what the Hindenburg was full of!
Pengwuino said:
Are you crazy?
Probably. So what?
Well, I hope you're being sarcastic - real Republicans talk pretty much like you do above, except that they generally don't ever admit to being confused.
Riiightt - Let's burn more coal in power plants, or coal gassification plants, (without any of those stinking EPA pollution controls, please!) to create hydrogen!
Now, we could make cars as fuel efficient as possible (hybrids) so they don't burn much fuel in the first place, but where's the money in that?
Krab, you are a smart guy to know how to calculate this, but honestly that is not the right approach. You admit your car gets very good gas mileage, yet you think 10 to 15% efficiency is not reasonable? Please. Most people I know do mainly city driving, and none of them drive through town, approach a stopsign, or park a car at a steady 60 mph. Driving highway speeds generally does increase efficiency, so I will have to stand by my original estimate.
yes I've gathered that hydrogen burning is efficient once you have the hydrogen. though my question, what additional energy loss should we expect creating hydrogen?
To me, it seems that a ground-up approach would be the most efficient method. Build your hydrogen production facility on the ocean shore (or an island) to forego having to transport the water, and use a wave-power generator for processing.
As a side note, such facilities in 3rd World countries could also incorporate desalination equipment to provide fresh water where there's a shortage.
As you have already guessed, you can expect fairly large losses, a point the speaker in the program I was talking about made, though I do not recall the figures at this late date.
One promising approach that was mentioned on the aforesaid program was "dual mode" hybrids. These would be hybrids that could be recharged from a power outlet as well as from the hybrid engine. For short trips, you could then have a totally electric vehicle - only trips where you exceeded the battery range would the gasoline need to be burned. This would give you all the advantages of an electric care (or a fuel cell car, or a hydrogen car) for short distances, with minimal changes in infrastructure.
If you take that approach, then the efficiency of a car is exactly zero. Consider that I drive to work and drive home again, Change in my energy state = 0. So all the energy was wasted. What I was talking about was how much of the energy in gas gets converted into useful force by the engine. Stop and go driving of course reduces fuel economy. Where is the extra energy? It heats your brakes. So you want to define efficiency your way? Then it is exactly zero.
im a simpleton, but as a simple ontopic comparison, what test conditions detirmined the 50% value of hydrogen cars, and is krab's or kingnothing's a more accuratly tested comparison.
no offence to either of you but i would proally support krab, because they proally detirmined the 50% as a very biased, support of hydrogen cars.
**just uninformed, mathematically handicapped deducing
if current car combustion runs at 25% efficiency. i would guess a unified petroleum factory would achieve a probable +50%... now I am just guessing, but I am pretty sure that's prior to expending the energy breaking the water bonds. which also would not be at 100% efficiency, and prior to the 50% hydrogen usage in cars efficiency.**
im proally wrong, but i think we might be lucky to get 25%. :confused:
but just a guess...
I've lived in California my entire life. I happen to know what kind of governor this guy was. I am sure you live in California too right? Because you are talking as if you know what its like to live here all your life. But wait a second, you couldn't even name the governor... how ironic.
The United States has some of the highest levels of coal available in the world. Obviously a good source. And you must have that selective-reading disease most ideologs have that make you have a seizure when anything about nuclear power or alternative fuels comes up so you just completely ignore it when you "read" the proposal.
And why is everyone talking about efficiency so much? Isnt the point of the hydrogen economy to pull us out of a depleting-resource need and into a resource that we can simply create almost out of thin air/using a much larger supply-resource?
The efficiency of a combustion engine is limited by the Carnot cycle: http://www.absoluteastronomy.com/encyclopedia/H/He/Heat_engine.htm
Think of the adiabatic temperature difference of the gas mixture from the combustion to the end of the power stroke. That's the work done. In practice this poses a definite limit on the maximum efficiency below 50%
No, I did not mean that. All I meant to say was that most cars on the road are not as efficient as yours are. I haven't taken an auto class in HS, but one of my friend's has, and he said that most cars get around 15% efficiency.
Maybe you should ponder that question a bit (why people are worried about efficiency), and ask yourself whether energy currently actually does "come from the air", or whether with existing technology it actually comes from burning coal, oil, and a bit of uranium.
While you've got your thinking cap on, you might ask yourself about some of the other assumptions you've made in this thread :-p.
My car is very typical. But nevermind my car. You can find values for Brake Specific Fuel Consumption (BSFC) at many websites. Here is one example. It appears that typical is 0.5 pounds per horsepower-hour. A horsepower-hour is 2.68 million joules. Energy density of gasoline can be found here. It's 44 Mjoules/kg, so 0.5 pounds of gasoline contains very close to 10 million joules. So you get 2.68 Mjl mechanical energy out with 10 Mjl gasoline energy in. This works out to an efficiency of 26.8%.
Look at the Holley website again. Some engines achieve 0.4 BSFC. That's an efficiency of 26.8% * .5/.4 = 33%! Now this is of course when an engine runs at optimum efficiency, but remember your first post:
We're talking about engine efficiency of internal combustion engines; not about how people drive.
Obviously, energy production by oil would be minimized. We're tlaking about future plans, not what would happen if it was implimented immediately into our current system because it would take a long time and to switch to nuclear power would be the best current long term solution. Hell and again that doesn't answer why anyones talking about efficiency. We're talking about ridding ourselves of the need for a resource that will be gone soon enough, not about picking and choosing what's the most efficient use of our resources. I don't think many people can intelligently say "Well... IC engines in our cars are more efficient then hydrogen... i say we should scrap the whole hydrogen idea!".
switching to nuclear power is fine, but isn't the entire point to reduce or stop ecological impact and damage?
I nominate you... i believe you diserve to run a nuclear disposale sight... maybe you can head up the neighborhood watch'
oh and ifficency is still a huge issue... would you enjoy it if your country created 200 new nuclear power plants, to create an inefficient energy expenditure?? and required 200 more to deal with the substantial losses required to produce it?
  • · Replies 17 ·
  • · Replies 96 ·
14K
