Is it maximum voltage or RMS voltage
8 replies · 4K views · last reply
jaus tail
Multiple-choice question: voltage phasor 25 at 15° V, current phasor 5 at -45° A, options A to D giving active and reactive power values; option C (62.5 W and 108.25 VAR) is selected.
I drew phasors and got the answer. Angle between V and I is 60 degrees. Cosine of 60 is 0.5. Then I multiplied V and I and divided it by 2.
I got answer 62.5. But I'm not sure if values of V and I given are rms values or maximum value.
Isn't formula for Power as: Vrms * I rms cos(angle)
So shouldn't it be: 25/1.414 * 5/1.414 * cos(angle)?
  • Multiple-choice question: voltage phasor 25 at 15° V, current phasor 5 at -45° A, options A to D giving active and reactive power values; option C (62.5 W and 108.25 VAR) is selected.
The book that I have (Power System Analysis by Charles A. Gross) write phasors using the rms value, i.e. the phasor ##V= \frac{V_{max}}{\sqrt{2}} \angle \phi##
Hi.
It is a convention to express the value of the voltage or current phasor as the RMS magnitude of it. Much like the passive sign convention, this is widely known and acknowledged in electronics, unless stated otherwise.
That is, if:
[tex]V_{m} \cos ( \omega t + \alpha)<br /> = \Re({V_{m} \cdot e^{j( \omega t + \alpha) } }) = \Re( {V_{m} \cdot e^{j (\omega t) } \cdot e^{j (\alpha )} } ) \underbrace{ \rightarrow }_{\text{Phasor domain/ transform} } \frac{ V_{m} }{ \sqrt{ 2 } } \angle{\alpha}[/tex]
The above is, of course, if you are using the cosine definition of a phasor, you can also use a sine definition in which case the signal would have to be phase shifted to the right by 90 (add - 90 ) to your cosine. The relation between peak and RMS for sinusoids is a result of the evaluation of the integral and using the definition of an RMS signal, the proof can be found online but the main concept is that the RMS value allows comparision with DC signals, as far as resistive elements are concerned.
Formula for average power in the AC domain is:
[tex]\frac{1}{2} \cdot V_{m} I_{m} \cos { ( \alpha_{v} - \alpha_{i} } )[/tex]
Where:
[tex]V_{m} I_{m}[/tex]
Refer to peak values.
When using RMS, V and I become respective values and the equation is :
[tex]V_{rms} I_{rms} \cos { ( \alpha_{v} - \alpha_{i} } )[/tex]
Your answer is correct as far as I know.
If you use peak values, you multiply by a half, and if you use rms, you get the same answer as the square root of two is present in both I and V rms.
Thanks for reading.
KM
In my opinion, the voltage and current are rms.
However, when you calculate the apparent power you have to use the conjugate current.
Okay. So if values are given in form V angle (45o) then V is the RMS value.
But if it's given like V sin (wt + 45) then V is maximum value. Right?
The result it is S[apparent power-VA]=P[active power-W]62.5+jQ[reactive power-VAR]108.25
In order to achieve this you have to multiply Vے α=V.cos(α),V.sin(α) by Iے β conjugate = Iے -β
I.cos(β),-I.sin(β).
I'm not sure.
From what I know:
draw V
draw I
and P is V times I times cosine of angle between them
Q is V times I times sine of angle between them
V = 25 angle 15
I = 5 angle -45
So this is
Phasor diagram: red arrow labelled V at 15 degrees, blue arrow labelled I at 45 degrees below the horizontal reference line, green arc marking the angle of 60 between them.
So P is V times I times cos 60... no sin term
Q is V times I times sin 60
I didnt understand this:
I.cos(β),-I.sin(β).
  • Phasor diagram: red arrow labelled V at 15 degrees, blue arrow labelled I at 45 degrees below the horizontal reference line, green arc marking the angle of 60 between them.
Since ,conventional, inductive reactive power has to be positive [and capacitive negative], if the current lags 15+45=60 degrees[ then the angle it is -60 degrees] then:
P=V.I.cos(+60) Q=V.I.sin(+60)
See –for instance:
https://en.wikipedia.org/wiki/Complex_conjugate
Handwritten phasor diagram with a blue dashed vertical arrow labelled I conjugate, a green dashed arc marked +60 and a green arc marked -60 degrees, a red voltage phasor V, a current phasor with 15 and 45 marked, and a blue arrow labelled I.
  • Handwritten phasor diagram with a blue dashed vertical arrow labelled I conjugate, a green dashed arc marked +60 and a green arc marked -60 degrees, a red voltage phasor V, a current phasor with 15 and 45 marked, and a blue arrow labelled I.
That phasor clears up the I* part. I never understood what its purpose was. Thanks.
