Is it necessary to study Euclidean Geometry before Differential Geom.?
The discussion revolves around the necessity of studying Euclidean Geometry before taking Differential Geometry, particularly in the context of preparing for a course in Differential Geometry. Participants explore the prerequisites and foundational knowledge required for success in Differential Geometry, including the roles of calculus, linear algebra, and topology.
  • One participant expresses uncertainty about the need to study Euclidean Geometry before Differential Geometry, citing a dislike for the subject.
  • Another participant asserts that studying Euclidean Geometry is not necessary, emphasizing the importance of being comfortable with basic analytic geometry, calculus, and linear algebra.
  • A later reply mentions that some Differential Geometry courses may not require prior knowledge of topology, while others might use it extensively, depending on the course structure.
  • Another participant suggests that undergraduate Differential Geometry typically requires strong multivariable calculus and linear algebra, along with some mathematical maturity, and notes that many courses use texts that introduce necessary topological concepts without requiring full abstraction.
  • Participants discuss the potential benefit of reviewing the course syllabus or textbook to gauge the prerequisites and content of the Differential Geometry course.
Participants generally disagree on the necessity of studying Euclidean Geometry prior to Differential Geometry, with some arguing it is not needed while others suggest it may be beneficial. There is no consensus on the role of topology in Differential Geometry courses, as opinions vary on its necessity and extent of use.
Some participants note that the requirements for Differential Geometry can vary significantly based on the specific course and instructor, leading to differing opinions on the importance of prior knowledge in Euclidean Geometry and topology.
Tosh5457
Hi, I'm a Physics undergraduate, and this semester I have the option to choose between Geometry (Axiomatic Euclidean Geometry) and other disciplines. In the next year I want to be ready to study Differential Geometry, but I don't know if I need to study Euclidean Geometry first. The teacher of D. Geometry told me it would help, but I really hate studying Euclidean Geometry, so if I could avoid it the better. What do you think?
No, you really don't need to study it beforehand. Of course, you need to be comfortable with basic analytic geometry such as finding equations of lines and circles. But I assume you know that from high school.
More important is calculus and linear algebra. That is going to be used quite heavily.
Thank you. My teacher also told me that I'll need topology, does differential geometry use it a lot?
Depends on the course. Some differential geometry courses require no prerequisite knowledge of topology and they introduce the necessary concepts during the course. Other courses use it extensively.
But if your teacher says you'll need topology, then you're probably going to use it a lot.
What book is your teacher going to use? Maybe you can read through his book or his syllabus in order to see if you're in over your head or not.
I'll check that. The teacher might change next year anyway, so I'll have to wait and see.
A lot of undergraduate differential geometry doesn't require much more than strong multivariable calc and linear algebra, and some mathematical maturity. Generally, it will be something like a "differential geometry of curves and surfaces" course taught from books like Do Carmo, O'Neill, etc. These books develop DG from a much more concrete, intuitive cases, and them abstracting them from there. They do build up some topological machinery, but never really to the full abstraction that's needed in a full course on topology. They usually just explain such concepts just enough to be applied to the course. For higher level DG, you need to be well acquainted with the language of smooth manifolds and such, which does require a bit more topological background.
The best thing to do would be to find out the book you're using, and see if you can get a syllabus from past classes. I actually found it useful to have learned DG from O'Neill before learning things like smooth manifold theory and more advanced diff geometry, because it provided motivation and examples of concepts I hadn't seen yet in full rigor.
  • · Replies 21 ·
