Is it okay to increase DC motor RPM by using higher voltage
Increasing the RPM of a DC motor by raising the voltage is not advisable due to the risk of damaging the motor and safety concerns. The discussed motor specifications include a voltage of 74V, an RPM of 1650, and a power rating of 1/75 HP. Alternatives such as using gears, sourcing high RPM motors from junked treadmills (90V DC motors capable of 6000 RPM), or utilizing vacuum cleaner motors (10,000 RPM) are recommended. Direct drive systems are preferred over gear systems for high-speed applications.
  • Understanding of DC motor specifications and limitations
  • Familiarity with voltage and RPM relationships in electric motors
  • Knowledge of sourcing and repurposing motors from appliances
  • Basic mechanical engineering principles related to motor design
  • Research high RPM DC motors suitable for cutting applications
  • Learn about the implications of using gear systems versus direct drive
  • Investigate the use of vacuum cleaner motors for high-speed projects
  • Explore safety measures when working with high-voltage motors
Hobbyists and engineers involved in DIY projects, particularly those focused on high-speed cutting tools and motor applications. This discussion is beneficial for anyone looking to optimize motor performance in custom machinery.
Pysiek
Hello guys
I'm looking for a motor for my arrow saw project. I would like to use it to cut carbon arrows. Found one motor in the shop that is pretty small and will work perfectly with my jig. But it's rpm's are only 1650 and I need at least 8000 RPM. Is it possible to increase the motor RPM's by increasing voltage? Motor specs:
Voltage - 74 DC
RPM - 1650
Amps - .4
Hp - 1/75
I would expect that you can exceed the specs a bit (like 2000 instead of 1650), but I really doubt that you can get 8000 RPM directly from the motor - I will probably ruin the motor, and it can be dangerous for you as well. There is a good reason why the specifications do not quote a larger value.
Gears might work.
That's what I thought. Looks like I need to go out shopping :-)
Look for junked treadmills. I gave got several 6,000 RPM 90 volt DC motors out of them. They ran okay on full wave rectified housepower with no filter capacitor, which would be ~120 VDC unfiltered so probably puts the motor in your speed range . An ordinary lamp dimmer gave me speed control.
Another thought - Vacuum cleaner motors run in the 10,000 rpm range but are noisy. You'd have to put an enclosure around it.
Another possibility is a blender ( I broke my 1000W Ninja blender under warranty and got the motor out of it...) or look for a damaged drill or dremmel type tool.
Blender sounds good. I might even have one :-)
It is best to avoid gears at those speeds and use direct drive, or an air motor.
High RPM motors are long and thin. Slow speed motors are short and fat.
A die grinder might be a good solution. Also a small router.
9K
  • · Replies 31 ·
