Is it possible to pump a swing 360 degrees?
It is indeed possible to pump a swing 360 degrees, particularly when the swing is connected by a rigid rod rather than a rope or chain. The key factors influencing this capability include the swing's length and the performer's position; a shorter swing and standing position reduce the moment of inertia, facilitating the complete rotation. Performers in circuses, such as Cirque du Soleil, successfully execute this maneuver using these principles of angular momentum.
  • Understanding of angular momentum principles
  • Knowledge of rotational inertia and its effects
  • Familiarity with the mechanics of swings
  • Basic physics concepts related to motion and forces
  • Research the principles of angular momentum in depth
  • Explore the effects of moment of inertia on rotational motion
  • Study the mechanics of swings and pendulum motion
  • Investigate circus performance techniques involving swings
Physics students, educators, circus performers, and anyone interested in the mechanics of motion and rotational dynamics.
rlaworms
Is it possible to "pump" a swing 360 degrees?
Is it possible to "pump" a swing so that it turns in a complete circle? Assume if you wish that the seat of the swing is connected to its support by rigid rod rather than a rope or chain.
Angular momentum
Li=Lf
We know that we can decrease or increase the rotational inertia by standing or crouching on the swing, respectively. However, we are not completely sure if those inertias alone will make it possible to swing in a complete circle.
Angular momentum
Li=Lf
I have seen performers at a "humans only" circus [like cirque du soleil] do it!
Edit: They were using a reasonably "short" swing, much shorter than you see in a children's park, and did it in the standing position, so will have been working with a reasonably small moment of interia? and yes, rods not chains.
Oh, thanks. I kind of understand the question now.
So, it is possible to swing 360 degrees...
