Is it safe to cover a floor lamp with an Aluminum metal pie plate?
The discussion centers on the safety and practicality of using an aluminum pie plate to modify an IKEA NYFORS floor lamp for improved reading light. Participants unanimously agree that while the pie plate may reflect light, it poses a significant fire risk due to heat retention, especially when used with fluorescent bulbs. Instead, they recommend switching to LED bulbs, which are more energy-efficient and generate less heat. Suggestions include ensuring proper ventilation if using any reflective materials and considering alternatives like LED bulbs with built-in reflectors for optimal lighting without safety concerns.
  • Understanding of LED and CFL bulb specifications
  • Knowledge of heat management in lighting fixtures
  • Familiarity with lamp modifications and safety standards
  • Basic DIY skills for implementing ventilation solutions
  • Research "LED bulbs rated for enclosed fixtures" for safe lighting options
  • Learn about "heat management in lighting" to prevent fire hazards
  • Explore DIY methods for creating reflective light modifiers
  • Investigate energy-efficient lighting solutions on energystar.gov
This discussion is beneficial for DIY enthusiasts, home decorators, and individuals seeking safe and cost-effective lighting solutions for reading or workspace environments.
12john
Please see the image below. I'm trying to convert my IKEA NYFORS floor lamp into a reading light, by covering the top with an Aluminium pie plate.
Will this be a fire or electrical hazard? Does anyone foresee any dangers or risks?
As I have 3 of these floor lamps in my attic, I don't want to waste money buying a reading light. I'm unemployed because of COVID.
If you have to ask a bunch of strangers on the internet if something is safe, the answer is "no".
You could save more money by replacing those fluorescent light bulbs with LED bulbs. You can buy LED bulbs for as little as $1 each, at IKEA and at Dollar Tree. The LEDs use less power than the fluorescent bulbs so that will save on your power bill.
The problem with those pie plate reflectors is not electric, it is heat. If the temperature in the lamp gets higher because of the plates, it becomes a fire risk and it also reduces the life of the bulbs, which costs you more money. So keeping the fluorescent bulbs and using pie plates will cost you more money, not less.
If you can attach it in such a way as to leave a gap (popsicle sticks and hot glue?) that would probably create enough convection to keep the light bulb cool. But I agree that a small led lamp should be cheap.
One more thing. You can also buy LED bulbs with built-in reflectors that direct light only downward. The one in the picture costs $7.22. I can also be dimmed.
Huh! That's what those are for! It never occurred to me that it was to concentrate the light in the downward direction to make a better reading light. Nice! :smile:
@berkeman The bases on the LED bulbs I've used get very hot. I think that would be a fire hazard IMO.
There can always be poorly designed bulbs. If the base gets hot rather than the top, that signals a badly designed power converter. Poor design is independent of the technology.
A key property to look for is whether the bulb is "Lamp Rated for Enclosed Fixtures" because that tells you about the cooling requirements. Misuse of any bulb in an enclosed fixture that is not rated for enclosed fixtures can result in overheating. The OP's question about use of a pie plate could convert an open fixture into an enclosed fixture unless ventilation is also provided as @russ_watters pointed out.
Good LEDs use less power and therefore generate less heat than good CFL bulbs. But today the difference is not great. CFL bulbs have continued to improve even after LEDs took over the market. Checking on energystar.gov:
LED, 9 watts, 800 lumens, power factor 0.8, lifetime 15000 hours
https://www.energystar.gov/productf...t-bulbs/details-plus/2286854#PriceAndLocation
CFL, 13 watts, 1040 lumens, power factor 0.6, lifetime 12000 hours
https://www.energystar.gov/productf...t-bulbs/details-plus/2292003#PriceAndLocation
What is the actual problem right now if using this lamp when reading?
Just put the lamp next to your arm chair and it should work fine anyways. No?
I'd be inclined to put two square section battens (say 25mm square) parallel, across the lamp shade rim and rest the pie dish on them. That will allow plenty of air circulation. It's got to be LEDs as CFLs have such disgusting light colours (I never saw a good one).
The "actual problem right now" is that (1) the downward light isn't bright enough, and (2) all the upward light (illuminating the ceiling) is wasting electricity and resources.
Put a photographic umbrella a few feet over the light stand, to catch all the light, and no problem with overheating then.
Or make your own to save cost with a normal umbrella and paste it with reflective material.
You get all the light downwards to your area, and adjustable too.
It should a nice ambience too
That would look 'exotic' and do the job very well but an aluminium pie dish (a big enough one) Plus two lengths of wood as spacers would not cost anything like as much. Supporting that brolly could be an expensive exercise too; it would possibly double the total cost. At that price, the OP could just go out and buy a more suitable liqht fitting.
Wouldn't have to cost too too much.
Just spray paint a small old umbrella lying around somewhere with white or silver paint and voila - a photographic umbrella to attach to the wall, on its own stand, to to the lamp. And umbrellas fold up nicely too.
Looks good too. Chic!
