DeadWolfe
- 457
- 1
Originally posted by Squeeze
The proof that there is no god:
The assumptions of god:
1. It has a personality or consciousness.
2. It is all-powerful and all knowing.
3. It controls all reality including the laws of matter or nature.
4. It has always existed.
Assumption 1 and 2 are critical in the proof that there is no god. In order to have consciousness and be all knowing requires a fundamental ability called memory. God must have some means to store information. Memory is a very definitive attribute; memory is the ability to sense information. In order to do that some state of something that functions as memory changes so as when acted on information can be determined. There is no other definition of memory and in fact the concept of memory is like the concept of a circle. The definition of a circle is all points along the arc are equaly distant from a common center. The circumference of the circle divided by it's diameter is always equal to pi. No matter how big or small the circle, no matter what type of universe you may find yourself in, the character of a circle remains.
Given that god must have memory and that part of god is a component of god which it did not create since god was not created and that component of god is governed by processes that abide by the definition of memory, then god is subject to elements that are governed by their nature and not the will of god! God ends up being a product of components one of which is memory.
This analysis from assumption 1 and 2 is an unavoidable conclusion, god is subject to the physics of the elements that it is composed of that are the governing processes of it's components. This truth disproves assumption 3 which states that god controls all reality including nature, since it's components govern how god operates on information and therefore is a form of nature that god does not control but is being controlled by.
Since god is controlled by elements that it is composed of it is not all-powerful and would suffer from problems of the uncertainty principle, which are based on whatever contraints of its nature, making it not all knowing!
Because god is composed of components and is therefore a subject of nature, it must devise methods to avoid destruction or entropy, so it must repair itself and must replenish energy.
Finally the elements god is made of had to exist first before they could compose into god, therefore god did not always exist.
If you prove that a being created life on Earth you still haven't proved that the being is a god. It's not that there is no evidence of a god, the concept of god is a nonsensical notion based on naive assumptions.
No. God does not need memory. Would you also suggest that to have a personality God needs a brain?
