Mentor
- 50,920
- 26,951
Frank Castle said:I have since spoken to this person trying to argue this point
Instead of you arguing with them, you could suggest that they sign up for PF and have us argue with them instead.
That said, there are a number of errors in what you have quoted from this person:
Frank Castle said:proper time is merely the number of reflections in your parallel-mirror light clock
No, it isn't. It's the invariant arc length along your worldline. If you choose units for that arc length appropriately, you can make the number you use to describe the arc length match the number of reflections in a light clock that is set up appropriately; but that doesn't make the two the same thing.
Frank Castle said:When you move fast through space, this reduces in line with the Lorentz factor which is derived from Pythagoras's theorem.
No, it isn't, except in the very, very weak sense that the spacetime interval involves the squares of coordinate differentials. But the spacetime interval has a minus sign in it where the Pythagorean theorem has all plus signs. That makes a big difference. To give just the most important difference: using the ordinary Euclidean distance (the one we get from the Pythagorean theorem), the distance between any two distinct points must be positive. But the spacetime interval between two distinct points can be zero; in fact, the squared interval can be positive, zero, or negative. There's no way to get that from the Pythagorean theorem.
Frank Castle said:if you could move as fast as a photon, there is no proper time
You can't "move as fast as a photon"; there is no way to make a timelike object move on a null worldline. The two kinds of things are fundamentally distinct.
Also, if by "there is no proper time" he means "the concept of proper time does not make sense for a photon", then he is correct. But I strongly doubt that is what he means; I strongly suspect he means "the proper time for a photon is zero", which is wrong. The arc length along a photon's worldline is zero (zero spacetime interval between any two points on the worldline), but that does not mean the proper time is zero; it means the concept of "proper time" does not make sense.
Frank Castle said:Time is a dimension in the sense of measure, not a dimension that offers freedom of movement.
If this were correct, it would prove that the three space dimensions also did not offer freedom of movement. Since that's obviously false, this argument must be incorrect. The error in it is to think that "a dimension in the sense of measure" is something different from "a dimension that offers freedom of movement". The two are the same thing--in fact the statement quoted above, once you observe that it applies to space as well as time, can be taken as a reductio ad absurdum argument showing that the two are the same thing.
Frank Castle said:proper-time and therefore four-velocity is simply not defined for light-like worldline. To parametrise a photons worldline one has to choose an alternative affine parameter.
Exactly. And this is why the concept of "proper time" does not make sense for a photon. You could try this on the person you're talking to; but I doubt if they understand the concept of "affine parameter" well enough to grasp the point.
Frank Castle said:Proper time is a frame independent quantity and so is fundamentally different to coordinate time.
Yes. More precisely, arc length along a timelike worldline between two chosen events is a frame independent quantity and so is fundamentally different to coordinate time.
Frank Castle said:It can be used to parametrise the worldline of a particle and to construct a well-defined four-velocity, so in this sense, why can't a massive particle be propagating along its worldline?
The issue is not that it can't be viewed as "propagating along its worldline". The issue is that the two statements "the particle is propagating along its worldline" and "the particle is described by its worldline and doesn't propagate at all, the worldline just exists as a curve in spacetime" both describe exactly the same math and exactly the same physical predictions. So there is no way to tell them apart within the domain of physics; as far as physics is concerned, they're equivalent, and neither one is more "right" or "wrong" than the other. They're just two different sets of words that describe the same physics. That is what other posters in this thread have been trying to tell you.
Frank Castle said:why can't the particle propagate along its worldline with respect to its proper time (otherwise does a particle exist at all points along its worldline)?!
Again, these two alternative sets of words--"the particle propagates along its worldline" vs. "the particle exists at all points along its worldline"--both describe exactly the same math and exactly the same physical predictions. So they are both the same as far as physics is concerned.
I understand that intuitively, the two sets of words seem to be describing different ways that things could be. But that's why we don't use ordinary language to describe physics when we want to be precise--because ordinary language can mislead us by making us think that two different sets of words that seem different to us must be describing different physics. That might be the case, but it might not--and in this case, not. The way to tell is to look at the actual math and physical predictions.
