Is Net Work Done When a Car Travels at Constant Speed on a Flat Road?
  • Thread starter Thread starter alwysnforevr002
    Car Flat Net Work
The discussion revolves around the concept of net work done by a car traveling at a constant speed on a flat road, exploring the relationship between motion, forces, and work in the context of Newton's laws.
  • Participants discuss Newton's First Law and the definition of work, questioning how these principles apply to a car in motion on a flat surface. There are attempts to clarify the conditions under which net work is considered to be done, particularly in relation to forces acting on the car.
Some participants have provided insights into the definitions of work and the forces involved, while others are exploring different scenarios to determine when net work is zero. There is an ongoing examination of the assumptions regarding forces acting on the car and the implications for work done.
Participants are considering various scenarios to assess when no net work is done, indicating a focus on understanding the conditions that lead to zero net work in different contexts.
alwysnforevr002
How much net work is being done when a car is traveling at a constant speed on a flat road?
I think there is not net work done.
:bugeye:
Think of Newtons first law and the definition of work.
Okay so Newtons First Law states:
An object at rest tends to stay at rest and an object in motion tends to stay in motion with the same speed and in the same direction unless acted upon by an unbalanced force.
However, that doesn't say anything about the work being done on the car simply that it stays in motion unless acted upon by another force.
What is the definition of work?
W = Fs x s
Please point out where the resulting force is acting in this example.
I looked up work as well and i think i understand now
The actual question is:
In which of the following scenarios is no net work done?
A car accelerates down a hill.
A car travels at constant speed on a flat road.
A car decelerates on a flat road.
A car decelerates as it travels up a hill.
I chose B , A car travels at constant speed on a flat road because there is no work upon the car as it travels along a flat road. The force supplied by the car is an upward force and the displacement of the car is a horizontal displacement. As such, the angle between the force and the displacement is 90 degrees. If the work done by the car on the road were to be calculated, then the results would be 0.
Am i anywhere close?
A car traveling at constant velocity along a flat road does no work against gravity -- however, it still does quite a bit of work against friction.
- Warren
So i am right?
As you have learned from Newton's First Law, a body will be still or move with a constant speed in a straigh line if no resulting forces is acting upon it.
As the care moves in a straight line with constant speed you can deduct that there is no resulting force.
Without a resulting force, it does indeed not have a net work (see the above given equation).
Does that help you understand the situation? Remember that there is a difference between getting the answer and understanding it ;)
haha..thank you. and yes that does help me understand it much better. It was the part about the resultant where i was getting confused.
  • · Replies 17 ·
